Help "service charging system"
Old Aug 20, 2009 | 01:56 AM
ArmySpeedFreek's Avatar
ArmySpeedFreek
Default Help "service charging system"
My voltage keeps dropping badly I need to know why asap
Old Aug 20, 2009 | 02:30 AM
ArmySpeedFreek
Yep car just died lol it's the alternator
Old Aug 20, 2009 | 08:35 AM
ArmySpeedFreek
Any one near Albany ny with an alternator?
Old Aug 20, 2009 | 08:41 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Wow !!!! a one man post........Good luck with the repair.
Old Aug 20, 2009 | 10:17 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Hell, he was on a roll! I didn't want to interrupt him!
Elmer
Old Aug 20, 2009 | 11:26 AM
quickc6's Avatar
quickc6
Elmer
Old Aug 20, 2009 | 11:48 AM
1stZ's Avatar
1stZ
OP, have you confirm that it is the alternator? I have the same message I see my DIC ("service chargeing system"). I've change my battery & it still doing it. So please give us an update once you have replace the alternator if it fix the problem. Subscribe! TIA
Old Aug 20, 2009 | 01:48 PM
ArmySpeedFreek
We'll i'm now stuck about 45 miles from Albany looking for an alternator
Old Aug 20, 2009 | 05:05 PM
Corvettes of Dallas - Parts's Avatar
0Corvettes of Dallas - Parts
Former Vendor
Sounds like the Alternator to me.
Good luck with the fix!
-Adam
Corvettes of Dallas
Old Aug 21, 2009 | 03:20 AM
HOXXOH's Avatar
HOXXOH
I feel your pain. I lost mine at 900 miles and I was 2000 miles from home then with a snowstorm about to hit.
I had the dreaded message once again today (49K showing), but the voltage floats between 11.0 and 13.3. It went to 9.0 to trigger the message and then back up to a higher range. I'm kinda baffled, but know something is gonna die real soon. Suspect a bad battery cell.
Hope you get back on the road again without a major hassle.
Old Aug 21, 2009 | 12:46 PM
ArmySpeedFreek
well i made it home on just a new battery the alternator kicked in a few times but it was not as bad as haveing to drive with just the battery at night
Old Aug 21, 2009 | 03:32 PM
Big Turkey's Avatar
Big Turkey
When you get the service charging system message, it is your alternator that is throwing the message. To determine if it's your battery, look at your voltage. You battery is a 12v source and should be floating between 13-14v. 12s is acceptable. Below that you have a dead cell in the battery most likely. You will know if your car won't start after letting it sit for a week or so but runs good after it gets a jump.
The battery is mainly used to start the car, the alternator does the majority of the work once the car is running.
Letting your battery die and then recharging it decreases the battery life, but if you're stuck out in the middle of nowhere then it's your only choice LOL.
Old Aug 23, 2009 | 11:23 AM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
I've been there and it was the battery and NOT the alternator. just sayin...
Old Aug 23, 2009 | 01:19 PM
928nomore's Avatar
928nomore
Default alternator
Had the same issue recently, actually the alternator worked as long as I kept it under 2,500rpm thereafter the voltage just crashed, I limped home and the dealer replaced the alternator ( I have also had 2 batterys go bed on this 08 (16,000 mi) best of luck w/ it
Old Aug 23, 2009 | 02:47 PM
HOXXOH's Avatar
HOXXOH
Fortunately mine (post #10) has healed itself. I topped off the water and within 100 miles it's back to normal. Hmmmm!
Wish the OP's could have been that easy.
Old Aug 23, 2009 | 03:03 PM
SgtRod's Avatar
SgtRod
I had a service charging system message om my DIC and it was not the alternator or the battery. Although this may be the cause for some it was not for me.
For me and a couple of other forum budies it was the SPARK PLUGS!!
Old Aug 25, 2009 | 06:12 PM
Wingrider's Avatar
Wingrider
I have the same problem. The message usually just flashes on for a second or so a the longest. My gage shows no discharge in voltage at the times that the message appears. According to the owner's manual, if there is a problem the DIC message should contiune coming on every ten minutes. I can go days without it coming on. Dealer says battery and alterrnator are fine. Probably a computer issue. (My spark plugs are the originals) 2006 A6. I know of no solution at this time.
To Help "service charging system"
Old Aug 26, 2009 | 11:17 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Me Too!!! SgtRod, thanks again for the help with that. Spark plugs causing a charge system fault would have been the last thing I would have ever expected.
Old Aug 27, 2009 | 08:52 AM
Wingrider's Avatar
Wingrider
Were your spark plugs OEMs or had you replaced them and then had the problem?
Old Aug 27, 2009 | 02:00 PM
SgtRod's Avatar
SgtRod
Your welcome!!! I always did wonder what happened with you. I know you went through hell to find it. I had a similar issue with my Active Handling. I felt your pain. Glad I could help Fly guy
Rod
