I found a broken spring. Need some help.
Old Aug 25, 2009 | 07:43 PM
commando57's Avatar
commando57
Default I found a broken spring. Need some help.
It was laying on the floor under the steering wheel. It is about 1.5 inches in diameter and has 3 coils and then it is broken. I have a pic I can email if you need to see it. Does anyone have any idea what it is for? Thanks in advance.
Old Aug 25, 2009 | 07:53 PM
svoshop's Avatar
svoshop
Clutch pedal has a spring to help with tension. Some remove it.
Mike
Old Aug 25, 2009 | 08:38 PM
DSOMvette's Avatar
DSOMvette
St. Jude Donor '09
Mike
Yep definitley the clutch return spring. Probably didnt even notice it was gone before you found it lying on the floor. Some replace em some dont. Mines been broke for over a year now and have replacement but have not taken the time to replace it. I havnt noticed any difference one way or the other, (some say they like the feel of the clutch without the spring) but some will say you need it if you track the car or drag it as it aids in the return of the clutch back to the original position to aid in the hydralics. There are several threads on this if you do a search and will list all the pros and cons.
Old Aug 25, 2009 | 08:43 PM
VET4LES's Avatar
VET4LES
Interesting post you might be interested in. I will replace mine if it ever breaks.
http://forums.corvetteforum.com/c6-c...ml?forum_id=74
Old Aug 25, 2009 | 08:50 PM
timd38's Avatar
timd38
GM would save the $0.11 a car if it wasn't needed.
Old Aug 26, 2009 | 12:36 PM
CMY SIX's Avatar
CMY SIX
if they wanted too, they would have! they did'nt put it in to waste money! replace it with a C5 spring you will like it!!!!!
Old Aug 26, 2009 | 04:47 PM
Drewstein's Avatar
Drewstein
Really? Have you not watched the news or are you talking about some other GM that makes smart decisions and didn't run itself into the ground...
Old Aug 26, 2009 | 04:50 PM
timd38's Avatar
timd38
Good point, but we did buy one.
Old Aug 26, 2009 | 07:26 PM
Wayne O's Avatar
Wayne O
CF Senior Member
The C6 clutch return assist spring was designed with a precise torsion for a specific purpose. IMO leaving the spring out or using an improper spring (i.e. the C5 spring) is not ideal and might cause premature clutch wear.
Old Aug 26, 2009 | 07:42 PM
HemiKLR's Avatar
HemiKLR
too funny... well not really funny but ironic. I just found mine on my floorboard... does it look like this???
Old Aug 27, 2009 | 08:36 AM
commando57's Avatar
commando57
I only had a bend and 2 coils, I was wondering where the rest of it was. I probably need to look up under there.
Old Aug 27, 2009 | 12:50 PM
lgm118icbm's Avatar
lgm118icbm
They did take away the hatch pull down handle. That couldn't have cost more than 11 cents....
Old Aug 27, 2009 | 05:38 PM
SnapperDragon's Avatar
SnapperDragon
I thought they did that for liability reasons because people would get their hand caught in it as the hatch closed down on their hand/wrist.
Old Aug 28, 2009 | 12:34 PM
lgm118icbm's Avatar
lgm118icbm
And the under hood light.....
To I found a broken spring. Need some help.
