Fast clicking noise from engine?
Old Aug 25, 2009 | 08:58 PM
Bat Man's Avatar
Bat Man
Default Fast clicking noise from engine?
Noticed this tonight, just cruising in 2nd or 3rd at 15-20mph, there is like a fast clicking noise that sounds like its coming from the engine. I've known some engine injectors to be loud, but never heard them while driving.
Is this normal for the LS3?
Old Aug 25, 2009 | 10:22 PM
MrDrezzUp's Avatar
MrDrezzUp
If it sounds sorta like a sewing machine...it is the valve train.
Old Aug 25, 2009 | 11:08 PM
Sparo2's Avatar
Sparo2
Does it get progressively faster as revs come up? If so, it can be your valvetrain. If it only gets progressively faster when your picking up speed then it's probably soemthing not associated with the motor.
Old Aug 25, 2009 | 11:09 PM
Bat Man's Avatar
Bat Man
Is that a problem? Or do the LS3s just have loud valve trains?
Old Aug 25, 2009 | 11:12 PM
Bat Man's Avatar
Bat Man
Not going to be able to drive it again until tomorrow. But I had the oil changed in it, and I checked oil level and thought it was low. But had Chevy mechanic check it again and he said it's a-ok.
Oil pressure is 28 at idle after proper warm up.
Old Aug 25, 2009 | 11:17 PM
Bat Man's Avatar
Bat Man
Ok, by sewing machine do you mean like this?
http://www.youtube.com/watch?v=WA4G_LDEflo
Cuz it does NOT sound like that, thank god
No it's way quieter than that.
Old Aug 25, 2009 | 11:54 PM
Icewind Dale's Avatar
Icewind Dale
Its totally normal. Look up other threads. Drive above 3000 and you don't hear the tick!
Old Aug 26, 2009 | 12:35 AM
MrDrezzUp's Avatar
MrDrezzUp
The sewing machine sound is normal for the LSx based engines. For the LS3, a padded "upper" was added to the manifold intake. I suspect this was to help cut down on the noise! :-)
To Fast clicking noise from engine?
