ms4 cam on c6 05 stick
Old Aug 26, 2009 | 12:06 PM
djwho's Avatar
djwho
Default ms4 cam on c6 05 stick
anyone got any thoughts about this cam was think about it in my c6. I am a young guy so i like it loud and annoying, but hp wise and is it streetable????
cheers
Old Aug 26, 2009 | 12:26 PM
FloydSummerOf68's Avatar
FloydSummerOf68
I hope you have some low gears in that thing.
The MS4 sucks for street driving. It's a complete top-end cam.
Texas Speed has some much better options for a streetable, aggressive cam.
Old Aug 26, 2009 | 10:39 PM
djwho's Avatar
djwho
Default icic
IC I dont wana install gears i jus want it to give me more high end what cam would u think too look at i was think about the 228 but it seems a little mild.
Old Aug 27, 2009 | 12:54 AM
MLCZ51's Avatar
MLCZ51
Default Way to big for you...
Originally Posted by djwho
ic i dont wana install gears i jus want it to give me more high end what cam would u think too look at i was think about the 228 but it seems a little mild.
will you do heads&cam..or just cam only???
I think you should look more at the 228/232 area..
Old Aug 27, 2009 | 04:29 AM
djwho's Avatar
djwho
ima do a cam now and heads probbly at home take them off an get ported or sumthing i was also considering the tv2 cam
Old Aug 27, 2009 | 07:45 AM
FloydSummerOf68
The torquer2 cam is a much better choice than the MS4.
Old Aug 27, 2009 | 09:17 AM
TurboVic's Avatar
TurboVic
cheers
Give LG motorsports a call and ask about their G6X1 or G6X3 cam. G6X3 cam will give you lope, loud, shake, tons of top end power and also streetable.
Old Aug 27, 2009 | 09:19 AM
FloydSummerOf68
Lol, you can also get damn near an entire cam package from Texas Speed for what LG charges for their grind
Old Aug 27, 2009 | 11:01 AM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
240 cam here, .608, 112 LSA. In the ballpark. 05 C6, stick. Love it. I don't need "mid-range" power. The 400lb/ft my car makes stock is more than enough to shove me around in traffic while just driving to get somewhere. I question just about everybody who touts that the "mid-range power is where you're doing most of your driving...". Well, sure, but if I'm just putting along in the mid-range, then I'm not getting on it. And if I'm not getting on it, why do I need my powerband there? The only time I need my car to be quick is when the pedal is on the floor. When that's happening, I'm over 4k rpms the whole time anyways. I don't understand the "low-end" logic, personally. I've never run anybody on a track or otherwise where we agreed on "hey, lets race between 2500 and 4500rpm's only, that'll be fun".
Go big or go home. Just don't go so big that the car wont idle or that it bucks and kicks all the way up to 2k rpm.
Old Aug 27, 2009 | 11:06 AM
djwho's Avatar
djwho
lg seems good and all its jus too much money
i think i will go with the torquer2 cam whats up with the lift diffrence between torquer2 and torquer3 is there good or bad?
Old Aug 27, 2009 | 02:52 PM
FloydSummerOf68
I use my cars power between 2500-4K rpms almost every day getting on it fairly agressively just to use the power.
I dont want to always be making 6500 rpm shifts to feel the power.
To each their own though. I dont think I've ever met anyone with a magic stick 3, let alone 4, that was happy with it as a daily driver.
Old Aug 27, 2009 | 03:50 PM
KBG's Avatar
KBG
I had a MS3 in my 99 SS......it was fine with the A4 and a big stall but was definitely not a low/mid-range cam.....had great results at the track with it though
I'm with the majority.....go with one of the torquer cams and u will have a much more streetable ride and won't lose much up top
Old Aug 27, 2009 | 04:53 PM
old motorhead's Avatar
old motorhead
I had the Torquer2 in my LS3 for a while. It's plenty loud and rumpy with an aftermarket exhaust. If you want to wake the neighborhood, the T2 will do it. Still drove fairly good with but a few issues. I wouldn't dream of going bigger, but I'm an old fart and I'm done with big cams and everything they come with. If you want to sound like you have a really fast vette, it will do fine. If you want a really fast vette, leave the cam alone, and add a blower.
Old Aug 27, 2009 | 10:29 PM
djwho's Avatar
djwho
blower is jus too much money
what kinda issuses did u have with it?
Old Aug 27, 2009 | 11:41 PM
TurboVic's Avatar
TurboVic
How much power/torque did your car put down with that cam?
Old Aug 28, 2009 | 11:14 AM
old motorhead
Main issues were low rpm surging. Some say you can tune it out, but I had two of Houston's best tuners have a go at it with similar results. That was with 4.10 gears. Stock gears would make it worse. Some can put up with it and shift it out of that rpm range. I couldn't.
It made about 460 rwhp in my LS3 with full bolt ons on a stingy dyno. Torque was up there as well. I think it was around 440. Similar cams get or exceed 500rwhp in LS3's on more #'s friendly dynos.
Old Aug 28, 2009 | 09:45 PM
djwho's Avatar
djwho
well i saw that like the lg cams and stuff make more power why is that tho doesnt make sense to me?
To ms4 cam on c6 05 stick
