New differential break-in?
Old Aug 28, 2009 | 06:40 AM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Default New differential break-in?
Just changed out to an RPM differential. What is the normal break-in procedure?
Old Aug 28, 2009 | 07:04 AM
BlackZ51Vett's Avatar
BlackZ51Vett
I dont know if they have specific instructions. If they did they should have told you. I would at least take a few hundred miles and vary speeds. No substained driving at high speeds. Other than that I would say you'll be good......
Old Aug 28, 2009 | 08:43 AM
TrenAman's Avatar
TrenAman
they told me 500 miles
Old Aug 28, 2009 | 10:32 AM
Ragtop 99's Avatar
Ragtop 99
I would ask them.
When I did a strange 12 bolt in my F-body, the break-in was 5 heat cycles. Each heat cycle needed to be 25 miles of continous driving with at least an hour cool down between cycles.
Old Aug 28, 2009 | 01:34 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I would also do some figure eight's in a parking lot to work the clutch packs in.
Old Aug 28, 2009 | 02:27 PM
PeterM's Avatar
PeterM
Default Break In Period.
I recently had a set of 390s installed in my 2008 M/Z51. Cartek did three heat cycles and then a fluid change. I also took it easy for 500 miles, and now all seems well.
Old Aug 29, 2009 | 05:51 AM
CPG1962's Avatar
CPG1962
Default Thanks
I assumed 500 miles and as many heat cycles as possible. I have a very easy 20 miles drive to work so 2 weeks or less will do it. I have the Quaife ATB so no clutch packs.
Old Aug 29, 2009 | 10:53 AM
saplumr's Avatar
saplumr
RPM did mine and didn't say anything about a break in period but did say fluid change was unnecessary.
To New differential break-in?
