2009 tpms
Old Aug 31, 2009 | 09:52 AM
Dan Wendling's Avatar
Dan Wendling
Default 2009 tpms
Are 2009 Tire Pressure Monitor Sensors the same as 2008 (C6)?
If so what is a good source?
Old Aug 31, 2009 | 11:04 AM
BEZ06's Avatar
BEZ06
Yes, all the C6 models from 2005 through 2009 use the same sensor - GM Part# 25758220 (well....if your C6 was built to European specs for delivery overseas it uses a different sensor).
Forum vendor Gene Culley ( http://gmpartshouse.com ) will have the sensors for you - around $250 for 4 of them.
I'm not sure about the 2010 C6 yet. There's some indication that it may use a different sensor, but I need to stop by a dealer, check the RPO colde in the glove compartment on a 2010, get a 2010 VIN, and check with the parts department to see what part# it uses.
If you look in the glove compartment at the sticker that has the RPO coldes on it, any U.S spec C6 from 2005-2009 should have the RPO code of UJ9 in with all the other codes - and that's the code for the TPMS computer part of the RCDLR that works with the sensor part# listed above.
One list of 2010 codes I saw had a code of UJM for the C6 (I think). If that's the case, the 2010 may use a different sensor.
Anybody with a 2010 who can verify whether the TPMS RPO is UJ9 or UJM??? Do you know what sensors are in your 2010???
Bob
Old Aug 31, 2009 | 01:05 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Just some added input,
2005-2009 part # 25758220 is gray in color, 315 mHz FM
2005-2009 part # 25758221 is orange in color, 433.92 mHz FM
2010 part # 15268606 is light green in color, 315 mHz AM
2010 part # 92186507 is black in color, 433.92 mHz AM
Old Aug 31, 2009 | 01:45 PM
Ragtop 99's Avatar
Ragtop 99
How do you know which frequency to buy?
Old Aug 31, 2009 | 02:02 PM
Eric D's Avatar
Eric D
I don't know for sure, but I believe the 433.92 mHz is for export. Hopefully someone else can answer this. If you have one out I would go by the color and buy the same color again. Bob's post above points to the gray 25758220.
Old Aug 31, 2009 | 02:56 PM
BEZ06's Avatar
BEZ06
Yes - that's correct!! U.S. spec sensors transmit on 315 mHz and the European ones on 434 (433.925) mHz. Some for the Japanese and Korean market transmit on 8xx mHz.
Here's a picture of the Euro spec tire pressure sensor for a 2005-2009 C6 (I don't know about the 2010+ Euro spec cars). You can see that it's orange in color, and it's GM part# 25758221:
A U.S. spec C6 will use the GM distributed gray peanut shaped sensor. Our sensors are made by Schrader, and you can get them from some sources directly from Schrader and they are red in color and Schrader Part# 20076.
Here's a picture of the Schrader sensor for a 2005-2009 that is distributed through the GM parts system:
And below is a picture of the same sensor made by Schrader, but distributed through other sources than GM:
The 2010 Corvette uses the same sensor used by the Cobalt, G5, 2006-2009 Tahoe, Suburban, Silverado, Monte Carlo, Impala, Cadillac DTS, some 06/07 Escalades.
I think this will be good news for 2010 Vette owners.
  • The green sensor is cheaper (about $45 instead of $65)
  • There are some aftermarket sensors that are even cheaper yet
  • You can program them into the TPMS without a tool - they will trigger if you change air pressure in the tire by about 8 to 10 psi (either let air out or put some in). You can also use a TPMS tool.
So....that's good news that you can program your sensors withouth an expensive tool. You'll need an air compressor to either add air or readjust pressures after letting air out, but that would be better than always needing a tool!!
However.....in January 2011 they changed the tire pressure sensor - same TPMS, but a different sensor. They changed to this black sensor, GM part# 20925924:
A 2010-2013 can use either the black or green sensor, and either one can be triggered during the relearn procedure by a TPMS Tool, but only the green one will also trigger by changing air pressure in the tire.
Bob
Last edited by BEZ06; Aug 5, 2012 at 02:09 PM. Reason: Updated picture links and info
Old Sep 6, 2009 | 10:23 PM
mtmsimple's Avatar
mtmsimple
4th Gear
it is right, the original part no. is 25758220 (315MHz) it apply for c6 2005-2009
If you wanto the another source, Orange Electronic Co.may good choice.
the same item of Orange TPMS no. is SC8220
(100% compatible, 1 year worrenty, the sensor can meet all the different wheel)
you can ask nearby tire shops, they can help you.
the cost is 40% off compare with Original. (sorry, no commercial)
just for your reference, thanks
Old Sep 6, 2009 | 10:37 PM
TigerVette's Avatar
TigerVette
I think you can program them into the TPMS without a tool - I believe they will trigger if you change air pressure in the tire by about 8 to 10 psi (either let air out or put some in).
So....that would be very good news if you could program your sensors withouth an expensive tool. You'd need an air compressor to either add air or readjust pressures after letting air out, but that would be better than always needing a tool!!
That's how my wife's 2008 Trailblazer works. I couldn't believe how easy it was.
Old Sep 7, 2009 | 08:33 AM
Ragtop 99's Avatar
Ragtop 99
Thanks! Good suggestion.
To 2009 tpms
