Your thoughts on 4.10s
Old Sep 1, 2009 | 09:54 AM
11sec_C5Z51's Avatar
11sec_C5Z51
Default Your thoughts on 4.10s
'05 C6 non Z51 w/G6X3 cam, LS6 ported heads, Lingenfelter ported LS2 Intake, ported TB, Vararam CAI, LG PRO LTs and Xpipe, B&B catback, tune. The car made 460rwhp 408rwtq and has ran 11.7 @ 125.7mph on the stock clutch. Adding a LS7 clutch/flywheel, FAST 92 and 4.10s, what do you think it should run?? and how much power would it pick up on the dyno with the new mods?
Old Sep 1, 2009 | 10:11 AM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
You probably wouldn't see much on the dyno at all. The clutch won't get you power, the FAST will give you more in the midrange, but probably only 15-20 RWHP at peak, and the 4.10s though increasing acceleration rate, usually show about a 10 RWHP loss on the dyno compared to the stock 3.42s...so your numbers may inly increase slightly.
BUT....those mods will make the car feel like a new animal....the low and midrange punch will feel like you lost 500lbs from the weight of the car....the FAST and the 4.10s do amazing things, especially with the non Z51 tranny. Just do it, you wont regret it.
Old Sep 1, 2009 | 10:14 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Call me....I'm sure we can help you.
Hey man... The 4.10 should have come stock in the C6! Ask any 4.10 owner and they'll tell you the same.
Life without 4.10s.... I'd rather DIE!
Chuck CoW
Old Sep 1, 2009 | 10:17 AM
07 Z51's Avatar
07 Z51
I love my 4.10s, even with the Z51 transmission. I should have done it much sooner. Why I waited, I'll never know................
Old Sep 1, 2009 | 11:41 AM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
You'll need some drag radials with those 4.10's
Old Sep 1, 2009 | 09:56 PM
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
I love my 4.10s (non-Z51 trans) and after 40k+ miles with them, I never get tired of driving the car.
Old Sep 1, 2009 | 10:44 PM
ETW's Avatar
ETW
You need tires before anything. Whats on it right now?
Old Sep 1, 2009 | 11:44 PM
GotVett?'s Avatar
GotVett?
Gotta find a setup to try. I want to feel this!
Old Sep 2, 2009 | 09:59 PM
PRE-Z06's Avatar
PRE-Z06
the 4.10s will give a huge sotp improvement, but you're gonna need a good tire to really feel it in the 1st 2 gears
Old Sep 2, 2009 | 11:00 PM
ChopShop1's Avatar
ChopShop1
Forgive my newb ? , but why would the 4.10s not be as good in the z51??? I thought all of the m6's came with the same gearing stock...
Old Sep 3, 2009 | 12:32 AM
drivinfast's Avatar
drivinfast
nope Z51 has different gear ratios than Base car and F55. so 4.10s in a base car are almost like 3.90s in a Z51.
no Z51 for 2010 unless it changes at the last minute
Old Sep 3, 2009 | 12:36 AM
drivinfast's Avatar
drivinfast
If you havent picked up a set of 4.10 gears my used ones are for sale, Ill make you a good deal since both of us are in Houston
http://forums.corvetteforum.com/c6-p...-new-pics.html
Old Sep 3, 2009 | 05:08 AM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Default Honest Opinions?
They arent for everyone. If you want to run the 1/4 then yes they are great - but you can do thatwith any ratio. With a HiHP Car you will be shifting constantly,every second, no matter what. I had my fun, got it out of my system, and ended up with 3.73's - I absolutely love them.
Old Sep 3, 2009 | 05:51 AM
SpinMonster's Avatar
SpinMonster
Your clutch and gears will get you a 10.9 ET with a 125 trap speed. The issue is that the power boost from the FAST may just put you over the top on the trap speed unless you use a taller tire than 26". You are on the line for trap speed with 4.10's at the track so I'm going to let hell freeze over and advise you to get 3.90's for this reason. Many people report increases in MPH and being at 126 now will get you the magic 128mph after the mods. I doubt the majority will fight the 2.3mph from the FAST although maybe one will.
Anyway 3.90's will get you what you want.
The LS7 is an awesome clutch but just be warned not many people other than Ranger will say its cut out for the track.
The last point is you will only see such an ET if the tire is a MT ET street and you have a decent 60'. The LS7 isnt going to make that easy.
Old Sep 3, 2009 | 07:12 AM
ChopShop1's Avatar
ChopShop1
Could you go deeper into this if you don't mind??? How is the non f55 z51 car geared???
Old Sep 3, 2009 | 10:28 AM
Ranger's Avatar
Ranger
Originally Posted by SpinMonster
...The LS7 is an awesome clutch but just be warned not many people other than Ranger will say its cut out for the track....
SpinMonster, not sure where you got that idea. Wasn't from anything I've actually written. On the contrary....
I've posted hundreds of times (one example) that the LS7 clutch has an ugly personality. It's the worst clutch for the track that GM has ever put in a Corvette I've driven. It's ill-suited for a 420 RWTQ car, much less one with even more power.
The LS7 clutch has a propensity to glaze and won't accept a launch rpm above 3600-3700 without compromising the 60' and/or the 330'.
It also produces prodigious clutch dust of elemental iron and copper that attacks the seals in the hydraulics leading to pedal issues unless the fluid is kept clean.
I've managed to adapt my driving to the limitations of the LS7 clutch through experimentation. That led to fast times at the track, in spite of the clutch's foul personality. Were I not a stock guy, I'd go with a better clutch and run much faster times.
Ranger
Old Sep 3, 2009 | 05:30 PM
SpinMonster
Ranger
I was complimenting your having gotten good results with it at the track. I will avoid naming specific people from now on. It always backfires.
I have an LS7 clutch in my car with well over 700rwhp and have never changed the clutch fluid. It was already over 500 when I installed it with a fidanza flywheel. My pedal never sticks to the floor which I believe is only due to heat issues weakening the springs in the pressure plate. Since I never launch hard, it never super heats. Those who have had the pedal stick to the floor note its only for a few seconds and then the pedal works right again....with the same clutch fluid. If the clutch fluid was the culprit it would not fix itself until the fluid is changed. My current fluid is about 3 years old.
I guess all this means I too have adapted the driving style to the clutch limitations. I agree 100% with the launch rpm limitations.
To Your thoughts on 4.10s
Old Sep 3, 2009 | 05:44 PM
Ranger's Avatar
Ranger
...My pedal never sticks to the floor which I believe is only due to heat issues weakening the springs in the pressure plate. Since I never launch hard, it never super heats. Those who have had the pedal stick to the floor note its only for a few seconds and then the pedal works right again....with the same clutch fluid. If the clutch fluid was the culprit it would not fix itself until the fluid is changed. My current fluid is about 3 years old...
Most clutch pedal issues occur on high-rpm shifts, not launch. Literally thousands of C5/C6 owners have cured pedal issues by keeping the clutch fluid clean.
Ranger
Old Sep 3, 2009 | 06:29 PM
drivinfast's Avatar
drivinfast
Search is your friend go to the top and hit the search and go to advanced and type "Z51 gears", select C6 you will get many posts
here are 2
http://forums.corvetteforum.com/c6-t...a6-vs-mn6.html
http://www.eorsr.us/c6
Old Sep 3, 2009 | 09:59 PM
ChopShop1's Avatar
ChopShop1
here are 2
Thanks man!!
