***question about throttle bodies***
Old Sep 3, 2009 | 02:43 PM
mattsc's Avatar
mattsc
Default ***question about throttle bodies***
HI DOES ANYONE KNOW FOR SURE IF THE 2005 THROUGH 2009 THROTTLE BODY IS THE SAME FOR LS2 LS 3 AND LS7
IF NOT CAN YOU BRAKE IT DOWN PLEASE.
THANKS....
Old Sep 3, 2009 | 08:39 PM
mattsc's Avatar
mattsc
Hey,where is all the smart/knowleable CF people ?
Old Sep 3, 2009 | 11:40 PM
chevybob's Avatar
chevybob
My ported LS3 was the same as a LS2. I heard the 2009 TB has changed.
Old Sep 4, 2009 | 11:22 AM
IPS Motorsports's Avatar
IPS Motorsports
The LS3 unit is not the same as the LS2 unit, similar but not the same.
Old Sep 4, 2009 | 01:57 PM
mattsc's Avatar
mattsc
Thanks IPS, so if I have a 2007 C6 and swaping the ls2 for an ls3 F/I I will keep the original ls2 throttle body ? Correct..
Old Sep 8, 2009 | 12:32 PM
IPS Motorsports
I am slightly confused, my apologies. So you have a built LS3 long block? that you are installing in an LS3 car? In this case I would stick with the stock throttle body in the LS2 car for programing .
-Brandon
Old Sep 8, 2009 | 02:57 PM
mattsc's Avatar
mattsc
Brandon ..I have a 2007 LS2 car that I am putting a LS3 F/I motor in.so which T/B and computor will I need
Old Sep 10, 2009 | 02:59 PM
WhItEKnIgHt23's Avatar
WhItEKnIgHt23
Spoke to Corey from LS2portworks and he said its the same. I installed his ported throttle body on my LS3 and externally it seemed the same and has worked like a charm.
To ***question about throttle bodies***
