90mm tb
Old Sep 8, 2009 | 01:47 PM
vet777's Avatar
vet777
Default 90mm tb
Will a LS3 90mm TB work with a LS2 intake?
Old Sep 8, 2009 | 03:17 PM
BEZ06's Avatar
BEZ06
I dunno!!!
However, the LS2 TB is 90mm, so I imagine the LS3 one would hook right up.
They're probably the same, but I'm not sure.
Edited: BTW, I just checked Gene Culley's site (gmpartshouse.com), and I couldn't find the info on the TB for a 2009, but when I checked for a 2008 it said:
Throttle body, corvette
05-08 $529.59 $529.59 $299.00
Includes Throttle Position Sensor.
So, still not sure, but the above indicates that the same TB is used on the 2005-2008, and I'm sure the 2009 and 2010 LS3 also.
Bob
Old Sep 10, 2009 | 02:59 PM
WhItEKnIgHt23's Avatar
WhItEKnIgHt23
Spoke to Corey from LS2portworks and he said its the same. I installed his ported throttle body on my LS3 and externally it seemed the same and has worked like a charm.
Old Sep 10, 2009 | 03:32 PM
Rich@pm-fl.com's Avatar
Rich@pm-fl.com
They are the same, you shouldnt have any problems
To 90mm tb
