Remove fuel line to remove FRC
Old Sep 7, 2009 | 02:44 PM
MisterC's Avatar
MisterC
Default Remove fuel line to remove FRC
The how to's that I've seen all show how the remove the fuel line under the FRC. Is there some reason the fuel line can't be removed just forward of the firewall?
Thanks,
Old Sep 7, 2009 | 03:26 PM
DONALD HALL's Avatar
DONALD HALL
The flex fuel line at the firewall disconnects the same as at the fuel rail. Remove clip, insert the special tool inside the fuel line to release tabs and pull line apart.
Hope this helps.
Donald
Old Sep 7, 2009 | 03:36 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Thanks,
If you're just removing the FRCs it isn't necessary. I covered the fuel line with plastic wrap, removed the FRCs and installed painted ones. No issues, scratches etc.
San
Old Sep 7, 2009 | 04:58 PM
Justasheet's Avatar
Justasheet
I bought the $7 fuel line disconnect tool from Advance Auto. I was a chicken sh-t!
Jeff
PS- Just remember to release the pressure by unscrewing the black cap on the fuel rail first or you'll be in for a surprise! Seriously, spraying gasoline is dangerous.
Old Sep 7, 2009 | 05:18 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Jeff
If it's dark you'll need a lighter to see what you're doing.
San
Old Sep 7, 2009 | 05:23 PM
Justasheet's Avatar
Justasheet
San
That's bad. You must be a firefighter. That's firehouse humor.
Old Sep 7, 2009 | 05:28 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Nope, just a smartass.
San
Old Sep 7, 2009 | 05:38 PM
MisterC's Avatar
MisterC
Jeff
There's a good heads up. I'd have never thought of it.
Old Sep 7, 2009 | 05:45 PM
Justasheet's Avatar
Justasheet
PM sent.
Old Sep 7, 2009 | 05:48 PM
Justasheet's Avatar
Justasheet
Default Here's the link
http://forums.corvetteforum.com/c6-c...fuel-line.html
Jeff
To Remove fuel line to remove FRC
