Stuck in 2nd - thoughts?
Over this week, shifting began to become slightly more difficult. Not much, but maybe 10-20% more effort was required to pop the shifter out of / into each gear. 1st gear from a dead stop has been denying me more often than before as well. I wrote that off though, as Corvettes have a tendency to do this even when new.
Today, I came through 1st gear at maybe 3/4 throttle, into second with some oomph at around 4k rpm, then when attempting to come out of 2nd at about 4k, the shifter wouldn't come out of gear. Completely stuck. Clutch feels fine, still requires typical pressure, has clean fluid, no leaks under the car. It still engages and disengages with no issue, allowing me to coast in gear with the pedal depressed, and engine brake when released.
I stopped the car, shut it off, tried to come out of gear, no dice. Tried manhandling it, still stuck. The shifter will come forward all the way to where it feels it's just about to pop into neutral, but won't quite make it. It still has typical spring-tension on it, so it doesn't feel like the linkage is busted. I called my tuner down in Florida, and his assumption was that it's likely a bent shift fork. Bad timing, as I just sold my DD Golf, and the Vette is on DD status.
What say the Corvette Forum?
Luckily the car shat itself within a few blocks of a buddy's shop, and I'll have it up on the lift tomorrow or the next day to start tearing everything down. Dropping the tranny on these cars is a pain in the ***.
Coincidentally, when I tried to restart the car, it wouldn't crank. Almost like the colum-lock issue, but with no Column Lock error on the DIC (although I have gotten that before). The check-engine light then came on, thereafter. I couldn't run the code, as I didn't have a scanner available at the moment.
Couple of things could have happened that would be better than a bent shift rod, and banging gears could have caused them.
One, the bolts on shifter box on the torque tube could have shifted from your shifting so hard. You might need to align the shift mechanism using a pin - loosen up the bolts, then there's an alignment hole to align everything in neutral, then you tighten those bolts.
Two, your pin on the rear of the shift rod that ties it to the transmission might have sheared or is in the process of shearing.
Those two items are cheapier than rebuilding the trans! I hope it's the easier, first one, for your sake.
Keep us posted!
Edit - here's some pics of what I'm talking about:
http://forums.corvetteforum.com/c6-t...ck-in-3rd.html
http://bit.ly/9Hpk3
The car was not left in 2nd for more than 30 seconds whilst fiddling with the shifter before attempting to restart it.Otherwise, a sincere thanks for the info. Some of the the OP's issues in that link are similar to what I'm having (the car not wanting to start back up now, even with full battery power), although the shifter movement characteristics he described don't quite match mine. Still, thankyou again, as it gives me something a little better to hope for.
It's definitely internal to the transmission. I'm trying to get the diff off of the back of the transmission now (the combo is out of the car and on the floor). 4 bolts removed that hold the diff to the tranny, and now when trying to pry them apart, I get about a mm or two of separation, but nothing more.
A few minutes after posting previously, I went back out and flipped the whole shebang over (just rotated it the first time in order to avoid spilling gear oil out of the top and all over the shop floor), and low and behold was a 5th bolt hidden under that bottom plate that is held on with two bolts of it's own. I assumed that plate was part of the diff's casing itself until I inspected further. Kind of a curious design.
Anyhow, I'm good to go now, the diff is covered and put away, and the tranny will be getting shipped out tomorrow to be looked over. I intend to have the builder replace whatever may be damaged, and execute a minor overhaul, i.e. forks, pads, keys being upgraded where possible.
Joe, would you happen to know if a C6Z tranny would bolt up under my '05? I realize I would need a different differential, but that would be a welcome upgrade regardless, as again, this POS is an '05.
There's a Z tranny with 4k miles on it for sale here on the forum, and I'm having a look at it.
