if you are talking wear your talking friction, friction slows a motor down, how is it my car is the fastest bolt/on by a long shot with all that wear
Gee, Mr. Dennis if you had one of them their stock T-stats, I'd reckon you be running 9s now.
I'm fairly sure that 2 factors drive the need for a higher T-stat in the factory design. As noted above, emissions requirements is a consideration. The second factor is oil temp. With the 160 T-stat, you do need to watch in colder climates that the oil temp gets warm enough to burn off the moisture. My oil temps mostly stay under 190 in the winter and often get no higher than 180*. That's less than ideal. I'll probably address that this winter, but factory car drivers don't want to worry about that.
that's 1 reason i have the 160 stat as to help keep my oil temps down as with my aggressive driving and low gears my rpm is higher at 70 mph then the stock car, even in the winter
I installed a 160 DEGREE THERMO in my ls3 and lost 4 mpg on a 90 mile run one way that I drive twice a week. Any thoughts on what may have caused the drop in mpg. The only thing that comes to mind is that the motor is not running hot enough to perform as before.
Thanks, C5-JIM
There has been over 40 replies to my question and I am no closer to a real answer. On Monday the stat will be removed and I will follow up with the real answer not some conjucture or thoughts.
Thanks to all that replied, C5-JIM
Could it be the gas? The pump stickers say may contain ethanol, my bulk distributor says some tanker loads have it and some don't depending on availability. Also you could have a lower octane due to the station tank fill, ie some regular in the premium tank?? Just a thought. I also really doubt it's the thermostat, your car doesn't run at 160* I'm sure.
I don't understand exactly what you are looking for.. all "ANYONE" can give you here is "conjecture or thoughts."
If you want a more "Exact" answer you'll have to take your car to a laboratory to conduct some very through testing with some very sophisticated equipment!
I personally thought you received some VERY GOOD replies... I honestly don't understand what more you could have gotten out of the question you asked and the answers you received!
Like one previous poster said nothing is for FREE... Most people here put in 160 T Stat to get improved performance.. at the cost of a few MPG... However if you are not interested in improved performance and are more concerned with gas mileage, you can put back the stock T Stat, and also look into changing the rear end gearing... and your highway mileage might improve, ... However your acceleration and the cars response to hitting the gas pedal may be a little slower.. but you cant have EVERYTHING... Its not a Perfect World!
Sooo, is the 160 worth doing? I just had my fans programed to run most of the time and was waiting for free time to do the stat. I'd rather miss 2hp and have my engine last 2000 miles more.
you did loss gas millage because of it being cooler the the car runs richer, the oil is a little thicker and the car runs faster and you are stepping on it more and i loss mileage to, so you have your answer, but you didn't loss 4 miles a gallon only 1, you must have had an oil change too and they put the normal 6 qts in over filling
Can an expert lay this to rest??
Thanks!
Rod
yes you should, and like one poster stated there tuner didn't recommend it, well ask him how many cars his tuner has put in the number 1 spotsthat 160 stat was for pure gas mileage, so you didn't have to pay a gas guzzlers tax, Winston cup cars do it for fuel mileage
Thanks!
Rod
Just curious.... "NOT BUSTING BALZ" when was the last time you heard of a small block (or Big Block) crap out or break because of a 160 T Stat ??
I agree I too would like to get an extra 2000 miles out of my motor.. but on my 96 C4 (LT1 motor) I put 70,000 miles on it many 1/4 mile at a time.. and when I sold it it was still running like a top.. (12.40 @ 110 mph) and it never had the heads off ever! I did have a 160 T Stat!
Sorry for adding a late "edit' Sgt. you said you had your fans programed to go on sooner.... "WHY" was your engine overheating, or running too hot???
Or did you do it to have your engine run cooler, & why ?
GM uses the high temp thermostat for emissions reasons, period. Higher temps reduce NOx emissions.
Emissions yes, fuel economy too. However, higher temps increase NOx emissions...they run a fine line there with A/F ratio and temps to get the right balance of NOx, HC and CO.
What tuners are you referring to? All the tuners I have spoken with use the lower temp tstat
All of the tuners that have built proven, fast cars and know what they're doing that is.
Originally Posted by KMK454
Well, they do design their cars with a committee of engineers and millions in R&D money, whereas Joe Tuner at the forum's favorite tuning shop...
This is true...and yet somehow "Joe Tuner" throws on a set of $1500.00 headers and $20.00 thermostat and with the press of a few buttons on a laptop finds up to 30+rwhp that this "committee of engineers and millions in R&D money" couldn't.
My tunner said he did this to keep the car cooler. He also said that once I put the 160stat in, the fans will relax a bit.
sorry, I did not observe any loss in mileage with my T-stat install, but I added headers and tuned the car, so I don't have clean before and after data. IMO, there are other factors at work if you lost 4 mpg including the possibility that your T-stat is bad and opens too early.
I could not find a laboratory in my small town but I did find a G.M. World class cert. mechanic who found the problem. There was a faulty A.C. relay that caused the A.C. compressor to stay on all the time. The problem is now fixed. He did state that a lower thermo change would cause the computer to add a little more gas than a stock one.
Thanks to all that replied.
C5-JIM
There is; fuel economy and emissions (both truly valid reasons to leave it in there of course...if going as fast as possible is of no concern to the owner that is).
I suppose that the Goodyear runflat tires and relatively soft rubber bushings that the car comes with are also the absolute best choice for all potential owner's needs/desires as well?
Sometimes yes, but not all of the time.
There's certainly nothing wrong with leaving a car bone stock but please don't ever assume that the factory put all of the absolute best performance parts (or programming) possible in the car when they built it either, there are always compromises and concessions made for various reasons. This is why the aftermarket world is so popular.
AGREED! Unless you buy a Veyron, but a Corvette is FAR from a Bugatti, even as much as some Corvette owners would want to disagree.
