putting in cam
Old Sep 12, 2009 | 01:47 PM
btstone84's Avatar
btstone84
Default putting in cam
anyone ever put a cam in the C6 without taking the motor out? is it doable?
Old Sep 12, 2009 | 01:54 PM
ShinodaVette's Avatar
ShinodaVette
It is definitely workable. I did mine that way the first time. Search around the forum a little and you'll find more details.
You can also get some good ideas here: http://www.robs427.com/htmpages/Cams...tallation1.htm
Old Sep 12, 2009 | 02:09 PM
chsmith112's Avatar
chsmith112
Yes you can, that's how mine was done.
Old Sep 12, 2009 | 06:39 PM
Amric's Avatar
Amric
That is how I did mine. The hardest part is pulling the R&P so the balancer can be pulled. Everything else was very easy relativly speaking.
Old Sep 12, 2009 | 11:52 PM
Nightstalker Medic's Avatar
Nightstalker Medic
Yes, very doable. That's how I did mine.
lolol Pulling the R&P was a little time consuming.
If you have someone close to you that's done have them give you hand. Four hands are always better than two.
Old Sep 13, 2009 | 12:27 PM
Slogo's Avatar
Slogo
Default R&p ?
What is R&P ?
Old Sep 13, 2009 | 12:28 PM
Amric's Avatar
Amric
Rack and Pinion
To putting in cam
