Engine click when cold
Old Sep 21, 2009 | 09:54 AM
427PWRD's Avatar
427PWRD
Default Engine click when cold
Hey all,
I'm new to the Corvette scene, and bought an '07 about a month ago. Everything seems to be in order, but I've noticed that when you first start the car in the morning, or whenever the engine is cold, it has a clicking noise when you accelerate. It clicks through all the gears (A6), and goes away when the engine is warm.
Is this normal? This isn't my first LS2, and my other one (GTO) didn't click. Any help would be appreciated.
Thanks in advance!
Old Sep 21, 2009 | 11:42 AM
Vito.A's Avatar
Vito.A
This is normal. In fact, if you listen closely you can even here it after it's warm, just not as loud.
Old Sep 21, 2009 | 11:46 AM
427PWRD's Avatar
427PWRD
Ah, gotcha. Okay then, I appreciate it!
Old Sep 21, 2009 | 01:31 PM
07MontRedcp's Avatar
07MontRedcp
Seeings how you have only had the car for a month, there is a small possibility that the previous owner did not use the recommended oil viscosity and that would aggravate the cold start noise.
BJK
Old Sep 21, 2009 | 01:44 PM
427PWRD's Avatar
427PWRD
BJK
BJK,
If that's the case, would an oil change with proper oil viscosity change that?
Old Sep 21, 2009 | 02:02 PM
pTr73's Avatar
pTr73
BJK,
I dont think it would hurt to try! Good luck.
07MontRedcp
BJK,
It will help IF the previous owner was using a heavier then recommended oil. 5W-30 Mobile One is the oil you should use. Wouldn't hurt to do an oil change now, if the oil on the dip stick looks dirty. It's an easy DIY if you are so inclined.
BJK
Old Sep 21, 2009 | 08:24 PM
427PWRD's Avatar
427PWRD
Thanks guys!
To Engine click when cold
