Tapping in engine
Old Sep 26, 2009 | 01:29 PM
texassoldier421's Avatar
texassoldier421
6th Gear
Default Tapping in engine
ok i have a zo6 and i have a constant tap in the engine does anyone have any idea what it could be or if it is a common problem
Old Sep 26, 2009 | 01:36 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Do you mean tapping or tappeting ? a very common problem
Old Sep 26, 2009 | 01:38 PM
texassoldier421
6th Gear
not sure it sounds like a lifter tapping on the older small block
Old Sep 26, 2009 | 01:40 PM
walterm32's Avatar
walterm32
Its not a problem, its just valve train noise. They all do it. I think more than half the people who buy a z06 wonder if somethings wrong when they first get one (myself included) because of the noise. No need to worry.
LSCHLEM's Avatar
LSCHLEM
You may be on to something.
Old Sep 26, 2009 | 01:45 PM
texassoldier421
6th Gear
thanks for your knowledge on these, this is my first vette and it had me worried. I was planning on getting rid of it if i couldn't figure it out. i am intransition from the military to the civilian sector and did not want a problematic car on my hands. so thanks for the reasurance
Old Sep 27, 2009 | 10:17 AM
Stage Runner's Avatar
Stage Runner
with walterm, same here........
ts421, thank you for your service....
SR
Old Sep 27, 2009 | 12:11 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Excuse me, but in order to make a educated diagnosis one would actually have to hear it.
What someone calls tapping could mean anything from the normal injector sounds, a header gasket leak, lifters, rockers, piston slap, or even a rod bearing.
My suggestion is to post a video with sound on YouTube so we can hear it.
Old Sep 27, 2009 | 12:36 PM
texassoldier421
6th Gear
i am currently stationed in germany and the car is in the states. I have dealt with many older SBC engines and the sound coming from mine sounds exactly like a lifter tap from one of the older engines. I did find out that my AC Compressor did go out.
Old Sep 29, 2009 | 07:51 PM
texassoldier421
6th Gear
Ok I had the car taken to the dealership and it was confirmed that I did have a lifter tapping, and they have have started trouble shooting why and what can be done to correct it. Thanks for everyones help.
Old Sep 29, 2009 | 10:14 PM
D-Rod's Avatar
D-Rod
Sounds pretty serious to me. I think you should sell it. Actualy I was looking for a project car. Ill even give you 30K for it.
Buy a set of Bullets for it and any engine noise will go away.
Old Sep 30, 2009 | 03:58 AM
texassoldier421
6th Gear
30K is enough to make me consider saling it
Old Sep 30, 2009 | 10:06 PM
turbo2001's Avatar
turbo2001
Default tapping
so what's concidered normal tapping on the valvetrain, cause i hear it on my c6 coupe also, head cam package 5000 mile's ltr it's still there, i did ask about it when i got the car back, and they said it's the afr heads?
Old Oct 8, 2009 | 01:14 AM
Invisiguard's Avatar
Invisiguard
my lifter blew up tonite, its becoming a problem
http://forums.corvetteforum.com/c6-c...gine-blew.html
To Tapping in engine
