Dash speaker cover removal
Old Sep 29, 2009 | 04:05 PM
HAD2HAV2's Avatar
HAD2HAV2
Default Dash speaker cover removal
How does one remove the dask speaker cover? I tried with a very small screw driver no movement but didn't push my luck.
Thanks,
Jim
Old Sep 29, 2009 | 04:22 PM
Vito.A's Avatar
Vito.A
It is just a push on installation with 6 clips. To remove properly, you need one of the small plastic panel removal tools, but a small screwdriver will work.
You pry up on the grill and look underneath for the clips. Just pick a spot and pry up looking for the clip, if there isn't a clip there, move over about 2" and try again. After you get two of the clips the rest will come easy.
The light/wire assembly will come up about 6" and allow you to rotate the grill out of the way. The center speaker is held on with 4 small metric hex head screws.
Old Sep 29, 2009 | 04:48 PM
RyanC7's Avatar
RyanC7
center channel? yeah, just pry up all around the edge, it comes out. I removed mine for my Sirius antenna with a custom plate.
To Dash speaker cover removal
