Torque Tube Problem
Old Oct 3, 2009 | 04:27 PM
dreed614's Avatar
dreed614
Default Torque Tube Problem
I have a C6 auto couple, with 30k miles, it has always had a small vibration when you accelerate. It also has a kind of clunk sound when your in slow stop and go traffic, what I would describe on a older car as a bad ujoint. I had it checked a couple of times and the dealer said it was normal.
Last week it got a lot worse, between 2k and 3k RPMs in any gear, it makes a very loud loose metal noise and the vibration is very noticable in the steering wheel. The dealer says something in the Torque tube was coming apart, they have ordered a new one.
Could someone explain the difference in a torque tube and a drive shaft?
Old Oct 3, 2009 | 06:52 PM
torquetube's Avatar
torquetube
The torque tube (in the IRS Corvette application) is simply a hollow tube that rigidly connects the engine bellhousing to the transmission/differential assembly in the rear of the car. The driveshaft turns inside the torque tube.
The driveshaft assembly consists of a short splined section on either end with a long aluminum shaft in the middle. The center section is attached to the ends with rubber couplings. All of this is inside the torque tube.
Old Oct 3, 2009 | 07:07 PM
VET4LES's Avatar
VET4LES
Old Oct 3, 2009 | 07:28 PM
HANNY's Avatar
HANNY
axle shafts can give you a vibration or clunking noise as well. Worth a look.
Old Oct 4, 2009 | 07:33 AM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Originally Posted by VET4LES
Cool Pic!
Old Oct 5, 2009 | 11:06 AM
dreed614's Avatar
dreed614
Thanks Guys
Now it makes sense. I will let you know what they find.
And yes Very Cool Picture
--Dan
To Torque Tube Problem
