Wheel width
Old Oct 17, 2009 | 11:26 AM
TerryLancaster's Avatar
TerryLancaster
1st Gear
Default Wheel width
Is there any problem with replacing the wheels on a standard C6 with the wider Z06 wheels?
Old Oct 17, 2009 | 11:31 AM
wooden's Avatar
wooden
yes the off set is different you will be sticking outside the fenders and most likely damage you fenders when the fenders bottom out on your tires
Old Oct 17, 2009 | 12:29 PM
Wayne O's Avatar
Wayne O
CF Senior Member
You can use 9.5" (or 10") wheels on the front but the 12" Z06 wheels don't really work on a stock body C6. You can, however, use Z06 rubber using 11" rear wheels with the proper offsets. My street wheels are CCW SP16A wheels, 9.5” x 18” front - 11” x 19” rear with the Goodyear Eagle F1 Supercar EMT’s...275/35ZR18 front / 325/30ZR19 rear...stock Z06 tires. This works very well IMO.
If you want a proper fitment with 12" rear wheels you either need to tub your wheel wells or make your C6 look like a Z06.
I like CCW wheels. They make a quality wheel at a reasonable price, they have superb customer service and John (at CCW) is a fitment expert. If you have any interest in CCW wheels I suggest you call John...he'll get you hooked-up right.
Old Oct 17, 2009 | 04:31 PM
Ragtop 99's Avatar
Ragtop 99
LG also sells a 19x11. They are pretty affordable too.
To Wheel width
