Car running hot!
Old Oct 21, 2009 | 09:21 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
There is some issues with the C6 fan controler plug- center wire (ground/black) burns up in the plug, and fan quits working.
several of us have had this problem!!
Old Oct 21, 2009 | 09:23 PM
c6 batmobile's Avatar
c6 batmobile
Originally Posted by Pelan
Well i think i got it figured out. Went out to the garage and let the coolant temp get up to 205* while i was under the hood with a light and guess what? Fans not coming on! Now my question is where is the connection so i can check that? THese are factory fans so maybe the warranty will cover that. I know i have the procharger but my tb was not resetting to 0 and they said that was covered. If it is not covered i am going to go with a dual fan setup and 160 t stat.
They should be on the passenger side of the radiator if I recall correctly. Its one big one I believe. Its been a while though. If you have hp tuners you should be able to turn your fan on and off at will. Try to turn them on if not youve found your problem.
Old Oct 21, 2009 | 09:26 PM
RareSS9596's Avatar
RareSS9596
Get the dual fans from Dewitts! Thats what I did after the Vortech install.
Old Oct 21, 2009 | 09:29 PM
Pelan's Avatar
Pelan
Thanks bud! I dont have HPtuners but i am sure this is the problem. I can see the fan blade itself and it is not moving what so ever. I will call the dealership and tell them my situation with the procharger. If it is not covered i will go with the dual fan from dewitts. I might as well milk the warranty IF it covers it.
Old Oct 21, 2009 | 09:48 PM
Pelan's Avatar
Pelan
http://www.dewitts.com/pages/product...asp?ProdID=427
Would this be the one i need if and when i take this route.
"This is an aftermarket add-on, and it is not compatable with the factory wiring or control system."
What would i need to make this work?
