Will C5 wheels fit C6?
Old Oct 22, 2009 | 08:33 AM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Will C5 wheels fit C6?
I have several set of C5 wheels and tires but am selling the C5 and getting a C6. Will my wheel setups work? I know I have to run a spacer on the rear to run C6 offsets on a C5. I am thinking that means C5 wheels would stick out on the rear of a C6?
Cajun
Old Oct 22, 2009 | 06:31 PM
haljensen's Avatar
haljensen
Cajun
Sell your C5 wheels and start a new collection for the C6.
C5 Diameters are wrong, most 17" won't fit the front C6 brakes, the offsets are wrong and the width is wrong for stock C6 or C6 upgrades.
Old Oct 22, 2009 | 08:19 PM
c6 batmobile's Avatar
c6 batmobile
Im pretty sure they well work but like haljensen mentioned the sizes are wrong and you wont be able to put the right size tires on them. They will actually set back in the wheel well a little and look kinda funny. I would just sell em and get some c6 sized wheels.
Old Oct 22, 2009 | 09:43 PM
jpee's Avatar
jpee
I have 2004 rear thin spoke 18x9.5" on the rear of my C6 for my race tires.. and they fit perfect, I also have the Z51 with bigger breaks...
Old Oct 24, 2009 | 11:39 PM
0Cajun @ Edgyvette
Former Vendor
Well the rears stick out on my C5 about 1" so maybe I can get away with it. I will test fit them just to check it out. If they dont fit then will sell them and get another setup or maybe just stick with the OEM wheels since they are the 08 gunmetal that look pretty clean anyway. Thanks
Cajun
Old Oct 29, 2009 | 10:12 AM
jhawtho911's Avatar
jhawtho911
Default C5 wheels fitting a C6
C5 wheels fit a C6 perfectly.
C5 Z06 wheels fit the front & rear of a C6 Z51 perfectly, no spacers needed front or rear.
See FinishLineWheels.com
Old Oct 29, 2009 | 10:57 AM
haljensen's Avatar
haljensen
I thought the C5 front wheels were 17"? My C6 Z51 18" wheels barely (1/2") clear the brakes in the Front.
The C5 18" rear wheels are 23mm less offset so they move the tire nearly an inch towards the fender of the C6.
Have to remember that the C6 has a narrower, shorter body on a longer wheelbase.
Old Oct 29, 2009 | 11:23 AM
jhawtho911's Avatar
jhawtho911
I am not sure if the 17" C5 Z06 wheels fit on the front of a C6 Z51 but I am positive the 18x10.5" C5 rear Z06 wheels fit perfect on the front. I have seen them on several cars running tires from 275/35-18, 285/35-18 to 295/30-18 on these wheels.
To Will C5 wheels fit C6?
