removeable top question
Old Oct 22, 2009 | 08:39 AM
cobraduke's Avatar
cobraduke
Default removeable top question
Believe it or not I've never had the top off my LS3 Coupe. Can one person do it, and how much does it weigh?:o
Old Oct 22, 2009 | 09:03 AM
Dan Wendling's Avatar
Dan Wendling
Default Depends on you
Post your picture with your shirt off and make a muscle! We can then tell you.
For the most part is is easy for nearly anyone to remove and install the top by themselves. Being over 5'9" is a big plus.
Open the hatch and make sure you have a clear area.
Put the windows down
Undo the top latches (all 3)
Open the driver door and stand facing the car with your chest against the driver edge of the top
Place your left hand at the front midpoint of the top and pull the top forward and up an inch or so
Place your right hand at the rear center of the top
Then pic up the top with a slight forward and up motion, placing the driver side of the top on your chest and tilting the passenger side of the top up
Walk back to the driver side rear wheel and lower the top into position
Place the front edge down first into the two latches
Press down on the rear latch after you are sure you have the two front latches mated correctly.
Same process in reverse.
lemonademan's Avatar
lemonademan
Default 1st time, have help
The top is easy to take off and handle for me, but I would have a helper for the first time. It can be a little tricky. The front pops up first, then the back.
Old Oct 22, 2009 | 10:03 AM
cobraduke's Avatar
cobraduke
Default Thanks
Here goes. It's nice in NC today so I'll try. Thanks again.
Old Oct 22, 2009 | 10:06 AM
Dan Wendling
Default No Pic Post
What no Pic Post !! I am disappointed !
Old Oct 22, 2009 | 10:13 AM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Check it out:
Old Oct 22, 2009 | 10:48 AM
DaveC6's Avatar
DaveC6
How about me? Think I could do it?
Old Oct 22, 2009 | 11:36 AM
TXC6Z51's Avatar
TXC6Z51
It's starting to get cold enough I might actually have to put mine on, its been a few months since it was even on the car.
Old Oct 22, 2009 | 12:02 PM
Dan Wendling
Default How tall are you
Dave:
Should be OK if you are over 5'8" tall when you stand up straight. Might be an issue of hitting your chin unless you tilt your head back a bit from your normal posture.
Old Oct 22, 2009 | 12:56 PM
Shortimer's Avatar
Shortimer
The video was a nice refresher. I've had the top off once to detail the the rubber and the get rid of a rattle.
Old Oct 22, 2009 | 01:02 PM
cobraduke's Avatar
cobraduke
Default great video
The short video was a big help. When I removed the top I didn't know which end went first into the storage compartment.
Old Oct 22, 2009 | 01:37 PM
drivinfast's Avatar
drivinfast
I had it good for the past 3 years, I had the original polycarbonate top that weighs less than the SMC does now. I just did the TSB where they take the hardware off the original and put it on the new and improved top to help stop the delam issue. Its definitely heavier now..im guessing a couple of pounds at least
Old Oct 22, 2009 | 01:41 PM
Robls6's Avatar
Robls6
That's gross
Old Oct 24, 2009 | 04:10 PM
VETTE RN835's Avatar
VETTE RN835
After having my boyfriend "stand by " if needed. Im now comfortable removing top myself....just needed to get the confidence to do it.. Im 5 7" ,so it is possible
Old Oct 25, 2009 | 06:24 PM
seevi's Avatar
seevi
I just had my top adjusted for the umptheen time by dealers from coast to coast. This last time the tech told me after installing the roof, make sure to keep the window switch operational for about ten seconds after the windows reach the top. This resets the window height to the new top position.
To removeable top question
