c6 problems
Old Oct 22, 2009 | 03:45 PM
scvette24's Avatar
scvette24
1st Gear
Default c6 problems
Ok so i am totally stuck. I have a 08 corvette that was wrecked and only had body panel damage thats it. I currently do not have any of the body pieces on except the doors and rear hatch. I am trying to get the car to cut on so I can adjust the doors and move it. When i close the doors the green light on the ignition switch will cut on but go out shortly after. When i hit the button to crank it with fab in car i just hear a click battery is charged. Does anyone have an idea on what this could be?
Old Oct 23, 2009 | 03:23 PM
VET4LES's Avatar
VET4LES
What does charged mean. Just because it shows 12 volts doesn't mean it's good or will start the engine. Have you had a charger on it? If your not sure take it to an auto supply shop that will check it for you.
Old Oct 23, 2009 | 03:42 PM
vette4jr's Avatar
vette4jr
St. Jude Donor '09-'10-'11
have airbags deployed?
hood on?
Old Oct 23, 2009 | 08:05 PM
c6 batmobile's Avatar
c6 batmobile
The car will start with the hood off. You may have a bad contact or a dead battery or a bad fob.
Old Oct 24, 2009 | 09:46 AM
Isaiah48's Avatar
Isaiah48
These Vettes are tempermental when it comes to needing full voltage for starting...
Old Oct 24, 2009 | 10:07 AM
oneblackvette's Avatar
oneblackvette
Foot on the brake or clutch in? Are you sure the switch is working?
And yes a full battery to start is needed.
To c6 problems
