couple of quick questions before i make purchase..
1) with the Z51 package are the sporties the way to go?
2) how well do they help reduce wheel hop on a M6 with over 450rwhp?
3) heard they are a little rough until they break in. how long is typical break in period?
4) where is best place to buy?
1. I made the swap to billie sports on my c6 z51 as well as my old c5z06 and loved it both time. Best-bang-for-buck in my opinion. I drive the car pretty hard at auto-x and track days and doubt this driver could take advantage of the difference between these and the high-dollar shocks.
2. I didn't do enough pre- / post-testing at the strip to have an educated comment on this.
3. Although I'd read about the break-in period, if I hadn't I probably wouldn't have noticed. I'd rate it as not a factor.
From: Beats UD regularly playing 3D chess, and at life
Is this a review of the "billie" dampers w/ no,none,zero other suspension changes, i.e. billie's w/ OEM Z51 leaf springs & sways?
Ride Q (it's fine as is): same, smother or bumpier w/ the change?
The only mod I've made aside from the billies
was the $30 pfdat poly sway bar bushings.
I'd rate ride --quality-- as unchanged overall during everyday driving. It's just pleasantly firmer during hard driving. I've driven stiff suspension c6s and these shocks are nice and mild.
i am very happy with the way the car drives with the oe shocks and the car never sees the track, i am much more interested in how it will address wheel hop. can anyone comment on this?
tks, dal
i am much more interested in how it will address wheel hop. can anyone comment on this? tks, dal
I switched to R888s at the same time as the shocks went in, so I can't comment on that-- my wheel hop is dramatically improved, but the sticky tires are going to be the main contributor.
You might PM Spinmonster on this, I think he did a pretty careful pre/post comparison when switching to the same shocks.
thank you. i understand. when i switched to the PS2's it helped a fair amount also. the best improvement in eliminating wheel hop is 90 degree weather. i am just hoping that the shocks take care of the rest. (or at least a good portion of it)
tks, dal
