Name that Spring
Old Oct 24, 2009 | 11:00 PM
Tecksun's Avatar
Tecksun
Default Name that Spring
So I hop in the car tonight and there's a spring on the driver's side floor, right about where my left foot would be.
Anyone have any idea where this came from? That's a quarter for perspective. The picture's a little washed out due to the flash... the spring is black and was covered in some pretty thick grease.
Old Oct 24, 2009 | 11:07 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I've never seen that spring. That said it's probably the clutch pedal spring. I've seen similar posts.
San
Old Oct 24, 2009 | 11:21 PM
Jcrumpley's Avatar
Jcrumpley
It is part of your broken clutch assist spring.
Old Oct 24, 2009 | 11:58 PM
Tecksun's Avatar
Tecksun
Thanks for the quick answer.
After a search, it looks like that's a fairly common issue and something that's easily replaced.
Old Oct 25, 2009 | 11:15 AM
Wayne O's Avatar
Wayne O
CF Senior Member
As mentioned, the clutch pedal return assist spring breaking is common and its an easy fix. I would, however, suggest you replace it with the proper replacement spring. Using no spring at all or replacing it with a C5 spring can potentially lead to premature clutch wear.
Replacing the spring only takes a minute but before you remove the remainder of the broken spring get down there are look carefully to see where it connects. Here's a couple threads that may help:
*this guy used a C5 spring but the replacement procedure is the same
http://forums.corvetteforum.com/c6-t...ing-in-c6.html
Old Oct 25, 2009 | 11:46 AM
BillH2121's Avatar
BillH2121
As said, it is an easy fix. But, if you're a "bigger" guy, it can be challenging to fit both shoulders in the foot well and get in position to push down the clutch with one hand and replace the spring with the other. I'm 6'1", 195 lbs, and had to have my wife sit in the passenger seat and push the clutch pedal down with a broom stick so I could replace the spring with one hand.
To Name that Spring
