trim panel / seat-belt replacement issue
Old Nov 2, 2009 | 05:42 PM
chadwick's Avatar
chadwick
Default trim panel / seat-belt replacement issue
I'm replacing the left-side trim panel in my convertible that the seat-belt feeds into and also has a hinge for the top.
In the 2006 service manual, pages 9-11 and 9-12 talk about removing the seat belt retractor for the convertible, but do not mention the trim panel as the coupe sections do. Page 8-471 talks about a similar trim panel in the coupe, but is different enough in the convertible not to work.
The issue is the end of the seatbelt is of course too thick too go through the hole in the trim panel. I'm likely just missing a step that makes this possible. Anyone done this before and know what I'm missing?
Images of said trim panel are here:
Old Nov 2, 2009 | 05:52 PM
Bill Dearborn's Avatar
Bill Dearborn
The slot in the coupe panel that the belt goes through pops out and you can then twist it and feed it and the belt through the trim panel.
Bill
Old Nov 2, 2009 | 05:59 PM
chadwick's Avatar
chadwick
Looks like the same technique does work with the convertible. There isn't an eschutcheon in the convertible's panel to pop out, but if you take the cover off the seat-belt faster and then disconnect the wiring you can squeeze it all, one piece at a time, through the slot. I was being too gentle.
thanks!
To trim panel / seat-belt replacement issue
