Pinging
Old Nov 2, 2009 | 06:38 PM
IRY's Avatar
IRY
5th Gear
Default Pinging
I have a 2007 Corvette Convertible standard 6.0. The highest octane I can buy in my area is 91 I add STP boost which give approx. 2 more points and the car still pings, is there a solution?
Old Nov 2, 2009 | 07:48 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
If you have tuner software (EFI or HP Tuners), it can confirm it's really pinging, under what condition, and by adjusting the KR tables, you can narrow it down to which cylinder.
But I have to first ask two questions:
1) How do you know its pinging? I mean, the factory PCM sensitivity settings on the knock sensors will pull out timing really quick so you should not hear it.
2) Has your car been modded and does it have new new tune? Because if it does, there are a number of setting that could have been changed...including reducing or completely turning off the knock sensors.
Old Nov 2, 2009 | 10:09 PM
knkali's Avatar
knkali
they ping right out of the box. Only cure is tune it
Old Nov 2, 2009 | 10:47 PM
Shortimer's Avatar
Shortimer
My '01 had a minor issue with pinging under WOT. A friend with a '97 had a similar problem. I had my car checked at a GM dealer who found nothing out of spec. Fuel injector cleaner didn't help nor did octane booster. I lived with it. No pinging at all with my '08.
Old Nov 2, 2009 | 10:59 PM
BigMay60's Avatar
BigMay60
You need to scan the car to see if you are getting any KR. This will confirm what you are hearing. Do you feel an loss of power...if the knock is bad enough you are hearing it, your car will be pulling alot of timing.
Old Nov 3, 2009 | 09:34 AM
SgtRod's Avatar
SgtRod
What is pinging? Is it a noise you can hear, reduced power, change in temp.. ect.?
Old Nov 3, 2009 | 06:23 PM
IRY's Avatar
IRY
5th Gear
Noise, like a ping
Old Nov 3, 2009 | 11:49 PM
SgtRod's Avatar
SgtRod
My car does this at start up sometimes... I had a tune by a reputable guy. What causes this(plugs,octane,Air-Fuel mix)?? Is it harmful or dangerous?
Old Nov 4, 2009 | 05:52 AM
REVAK's Avatar
REVAK
I have had a similar experience. Tuning can totally eliminate it. Also it is beneficial to run a 160* thermostat and 1 heat range colder on your spark plugs. Cold air induction is also very helpful in mitigating this condition. As you reduce heat , you reduce the amount of timing you have to retard to reduce the pinging . The more timing you can keep, the more power and throttle response you will have. Another alternative is to kill it with octane, but that is expensive, the 2 points you referenced is actually .2 octane units , you would have to use 5 bottles each tank to raise 91 octane to 92 octane. And 92 still isn't enough, 94+ seems to be the magic number at sea level.
Old Nov 4, 2009 | 11:19 AM
IRY's Avatar
IRY
5th Gear
Thanks, I'll try the tune and thermostat
Old Nov 4, 2009 | 07:33 PM
dkrhardy's Avatar
dkrhardy
IRY - if you still have warranty, and on a '07 I'm sure you do ......... a tune will void the engine/trans/diff warranty. BEWARE!
To Pinging
