Check engine light in 09
Old Nov 7, 2009 | 01:39 PM
tomiboy's Avatar
tomiboy
Default Check engine light in 09
I had my check engine light come on over a year ago for an hour or so then go out. This week it came on while I was driving and the next time I took it out, it went out in about 2-3 miles of driving and a couple of stops at stores.
Should I take it in for this or is this something that ocassionally happens. It is not a daily driver, if that matters.
Thanks!
Tom
Old Nov 7, 2009 | 06:18 PM
AFVETTE's Avatar
AFVETTE
Once a CEL is triggered codes are generated that will identify the fault, even if the CEL goes out the code is retained in the history.
If you don't want to buy a ODBII coder reader, or take it to a dealer any local Auto Zone or Advanced Auto will loan you a coder reader.
Once you have the code it's easy to determine what the problem is, but the CEL doesn't come on for no reason.
Get it checked.
Old Nov 7, 2009 | 06:38 PM
Shortimer's Avatar
Shortimer
Faulty gas cap will trigger the CEL. That's just one possibility. Keep us posted.
Old Nov 7, 2009 | 09:47 PM
tomiboy's Avatar
tomiboy
Thanks! I'll stop at the dealer and see what's up.
To Check engine light in 09
