temp readout problem
Old Nov 8, 2009 | 11:19 AM
daveven's Avatar
daveven
Default temp readout problem
anyone ever come across this problem ? i'll be cruising along at normal running temp when all of a sudden the temp readouts on the DIC and analog gauge will change by 50-60 deg. it could go from 185 to 135 in seconds then go back to normal again in seconds. there is no problem with the cooling system as far as i can tell. wondering if i have a bad coolant sensor.
