A4 = 700r4?
Old Nov 17, 2009 | 12:36 AM
LBear's Avatar
LBear
Default A4 = 700r4?
Is the "A4" found in 2005 C6's and all C5 automatics, the "infamous" 700R4 transmission?
Also, what is the "A6", is it the 4L60E transmission?
Old Nov 17, 2009 | 03:52 AM
glass slipper's Avatar
glass slipper
The 2005 C6 A4 is basically the 700R4. The 700R4 was renamed the 4L60 when GM went to an alpha-numeric designation for all transmissions. The "4" refers to the number of forward gears, the "L" refers to longitudinal orientation ("T" refers to transverse orientation), the "60" is a relative strength indicator, and the "E" means its electronically controlled. The A4 in the C6 is called a 4L65E which means its beefed up over the 4L60E to handle the higher torque of the LS2. The 4L60E is rated at 360 lb-ft and the 4L65E is rated at 400 lb-ft, so its not exactly the "infamous" 700R4.
The A6 is called the 6L80E. As a reference point, the Turbo 400 was renamed the 3L80 which puts it on par with the strength of a Turbo 400.
Old Nov 17, 2009 | 12:51 PM
LBear's Avatar
LBear
THANKS for the info! My C5 had the 4L60E and it grenaded after only 10k miles. I always knew and heard that the 700R4/4L60E were not that great when it came to handling power/torque.
I'm glad GM finally came out with a stronger auto. Man, the Turbo 400 was a beast, that thing handled almost anything you can throw at it. A buddy of mine has a muscle car that makes around 550HP/600LBS Torque and it has a stock Turbo 400 and even after hundreds of hard 1/4 mile runs and tens of thousands of miles, it hasn't skipped a beat.
Hopefully the 6L80E is as reliable.
To A4 = 700r4?
