New Dyno #'s!!!
Nov 18, 2009 | 09:54 PM
New Dyno #'s!!!
Mods in sig...wore down my Mcleod clutch and instead of rebuilding it I decided to swap it out for the RPS LSX BC2 clutch...old dyno #'s were 510/460 on old setup...the pulls below are with the new clutch with and without my belts...now i just have to get used to how this clutch grabs when trying to drive off in 1st gear...already killed it once at the gas station on the way home...hahaha...big thanks to LG for the help and work!!!
Nov 18, 2009 | 09:58 PM
No suprise, I knew your car was a beast after watching it run at the track! Guess you won't be making it out again this year with the new clutch?
Nov 18, 2009 | 10:09 PM
Quote:
Originally Posted by
PRE-Z06
I will be at the track before the season ends...don't worry...hahaha...just have to get used to this new clutch 1st
Nov 18, 2009 | 11:27 PM
nice numbers
Nov 18, 2009 | 11:54 PM
Nice gains.
dsp300c
And hopefully get some solid street/break in miles on it before abusing it at the track as well.
Nov 19, 2009 | 03:56 AM
Nov 19, 2009 | 08:01 AM
Thanks. Now let's hope I can learn this clutch before the face season is over.
Nov 19, 2009 | 10:07 AM
Congrats man. I will be in Lewisville in a few weeks, sent you a PM.
Nov 19, 2009 | 12:21 PM
You will get used to it, or I will drive it
Thats the highest number Ive seen out of a 3.622(stock LS1/2/3/6) stroke engine!!
Nov 19, 2009 | 01:13 PM
Louis @ LG Motorsports
No doubt!
Isn't the hp and tq on par with a small sized cam only LS7 Z? Maybe more low end and top end tq from the LS7 but still close right?
I'm very impressed. Can't wait to see it in person.
Nov 19, 2009 | 07:01 PM
LEAVINU
No doubt!
thanks...see ya in december
Nov 19, 2009 | 07:02 PM
St. Jude Donor '08
Nov 20, 2009 | 05:25 AM
What did it do with the belts on????
Nov 20, 2009 | 08:21 AM
a9secVette
it is on the graph...one of the pulls is with the belts on and one is with the belts off...it did 525.xx/477.xx with belts on...531.xx/483.xx with belts off
Nov 20, 2009 | 08:25 AM
St. Jude Donor '08-'09-'10
Good numbers and you still have a good bit on the table. FAST 92 and 100
mm MAF + TF's for starters though I havn't seen much from the new FAST I guess
the 100mm FAST cant be used because the TF's are cathedral but IMHO i still think its better than the l92/l76 COMBO. . Good luck at the track. Leon
Reason: DID NOT READ SIGNATURE
