Gas Pedal Potentiometer(s)
Old Nov 21, 2009 | 08:28 PM
Enzo Bertaggia's Avatar
Enzo Bertaggia
Default Gas Pedal Potentiometer(s)
Can anyone tell me about the Potentiometer(s) on the Gas Pedal of a C6? How many are there? What is the voltage range for each of them?
Thanks,
Enzo
Old Nov 21, 2009 | 09:19 PM
timd38's Avatar
timd38
My bet is that most people don't have clue what you are taking about, me included!
Old Nov 22, 2009 | 07:09 AM
mikeci's Avatar
mikeci
Thanks,
Enzo
OK I looked for about a 1/2 hr in the manual and came up w/ this; there are 2 throttle senors in the gas pedal. sensor 1: has a normal range 4.75- 0.35 V Sensor 2: 0.25-4.59v these numbers are under various engine running conditions. there is also a 5v reference point.
that's the best that I can do.
BTW why do you want to Know?
Mike
Old Nov 22, 2009 | 08:41 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default There is only one " TPS"
Mike
"TPS" is for throttle position sensor. The voltage is 0- 4.95 VDC, which
represents the position of the butterfly being fully closed to full open.
You can monitor this with a good SCAN TOOL like the predator, HP TUNERS or other CORVETTE DESIGNATED ROOLS. You dont even need the motor running to run the voltage up and down . A great way to check if there is a dead spot if the engine is doing something like stumblimg or just not followowing the pedal 100%.
Old Nov 22, 2009 | 11:30 PM
HANNY's Avatar
HANNY
the job of the TPS on the butterfly is to tell the ECM how far the throttle plate is open.
You also have a throttle "sensor" on the pedal. its job is to read the position of the "pedal" as you push it.
Old Nov 23, 2009 | 12:25 PM
GHWelles's Avatar
GHWelles
Thanks,
Enzo
Are they pots? I would be concerned with reliability, variation in spec, etc.
Old Nov 24, 2009 | 03:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
They are very precise wire wound resistors and use a sweeping arm to pick up the voltage on the wire wound resistor.
I bet there are more than one. It has to have more than one.
GM uses redundant circuits to provide throttle by wire safety feed back. Normaly the redundant pots operate oposite of each other. When one pot reads .03 Volts the other pot reads 4.97 Volts. If the voltage are not equal/oposite, it will but the PCM in the REDUCED POWER MODE!
BC
Old Nov 24, 2009 | 05:13 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
BC
BINGO!! I knew there were two and that they read opposite of each other so that the total of the two voltages is always the same. I just didn't know the voltage specs, but Mike chimed in with that.
To Gas Pedal Potentiometer(s)
