Heades and cat-back
Old Nov 22, 2009 | 02:41 PM
Domestic Disturbance's Avatar
Default Headers and cat-back
I have decide to do the full exhaust and take my chances with the warranty. My question is the size of header primaries and exhaust pipes. Should I use 1 7/8 or 1 3/4 headers and do I go with 2 1/2 or 3" cat-back. I am really leaning towards American Racing LT's and Borla cat-back. I welcome all suggestions from every one. Ya'll are the best.
Old Nov 22, 2009 | 03:16 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Your profile is blank. Fill it out to get better answers.
The difference between 1 3/4 or 1 7/8 LTs isn't worth talking about, unless you're making ungodly amounts of power. Sam (PowerLabs) proved this some time ago. Catbacks don't make power, unless you consider 2-6 rwhp "power". They are good for sound, not power. I'd save the catback money for something that will actually make power.
San
Old Nov 22, 2009 | 04:02 PM
saplumr's Avatar
saplumr
The only way to gain power behind the headers is a offroad x-pipe at maybe 4hp. Been there and back to high flow cats so it's not worth it.
Old Nov 24, 2009 | 05:08 AM
07 Z51's Avatar
07 Z51
If you are not planning on doing serious HP mods, I would use 1 3/4 headers. Otherwise, 1 7/8 headers.
I would not get the Borla cat back.
I would get the entire exhaust in 3" and then I would pick up a set of OEM mufflers off a Z06. That way, the Z06 mufflers bolt right up, you have the ability to control the system with an NPP in a Box and you have it all - a larger exhaust for future mods, all in 3" so no need to cut up the Z06 mufflers and make them work with your 2.5 " exhaust, and the ability to open it when you want it loud and close it for silence.
Old Nov 24, 2009 | 06:52 AM
[QUOTE=07 Z51;1572221478]If you are not planning on doing serious HP mods, I would use 1 3/4 headers. Otherwise, 1 7/8 headers.
I would get the entire exhaust in 3" and then I would pick up a set of OEM mufflers off a Z06. That way, the Z06 mufflers bolt right up, you have the ability to control the system with an NPP in a Box and you have it all - a larger exhaust for future mods, all in 3" so no need to cut up the Z06 mufflers and make them work with your 2.5 " exhaust, and the ability to open it when you want it loud and close it for silence.[/QUOTE
If not the Borla - suggestions
Old Nov 25, 2009 | 11:29 AM
mitchydkid's Avatar
mitchydkid
His suggestion, instead of Borla, is to put Z06 mufflers on.
-D
To Heades and cat-back
