Drivers window problems
Old Nov 27, 2009 | 08:37 AM
Boomer1864's Avatar
Boomer1864
2nd Gear
Default Drivers window problems
I own an 05 C6. When I go to close the door or unlock the car the passenger window drops the apprpriatte 1/4th inch. The drivers window doesn't which makes shutting the door a chore. any ideas on why this one window drop feature stopped working. Thanks in advance to those of you with more Corvette experience than myself.
Old Nov 27, 2009 | 08:46 AM
Andy 53's Avatar
Andy 53
Sounds like you need to re-index the window. With the ignition on, lower the window, close the door, roll the window up and hold the switch up for three seconds. Lower and repeat process. If there is no other problem, that should fix it. Each window has to be done separately.
I'm also a new owner and just recently learned this tip. Hopefully, I have it correct!
Hope this works for you!
Andy
Old Nov 27, 2009 | 09:52 PM
Boomer1864's Avatar
Boomer1864
2nd Gear
Thanks Andy. That fixed it.
PS. Your the Man!
Old Nov 27, 2009 | 10:45 PM
Andy 53's Avatar
Andy 53
Glad to be of help!
I was frustrated by the same problem when I had to change out my battery.
Andy
To Drivers window problems
