Headers Question
Old Dec 1, 2009 | 03:42 PM
jpuli28's Avatar
jpuli28
Default Headers Question
Before I buy a set for the 07 LS2 (A6)....
Whats the difference/purpose between 1 7/8 and 1 3/4 applications? I even saw a set with 2" primaries.
Do I want coated or not coated?
(I heard coated will keep heat in the heads, true? Uncoated will raise underhood temps, true?) Which is the lesser of two evils?
I do want 'em catted.
Old Dec 1, 2009 | 06:24 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
In order to offer assistance/opinion would be helpful to know what your goals are.
Old Dec 1, 2009 | 06:39 PM
jpuli28's Avatar
jpuli28
Looking for just a few bolt on ponies.
Already have...
CAI/VettAir/Flowmasters
Want...
Headers/Xpipe,cats/Ported TB/Ported Intake
Car is a DD. No intention of tracking.
Old Dec 2, 2009 | 04:24 PM
mjorgensen's Avatar
mjorgensen
If you oversize the primaries you will loose power from incorrect scavenging through the bottom end and midrange. It may flow more on top end but will cost you more overall. I would go for the correct size for the exhaust port you have now unless you are going to use forced induction down the line.
Old Dec 2, 2009 | 05:38 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Both sizes will work great. If you ever plan to upgrade to bigger cubes in the future, I would choose the 1 7/8" primary. Most all of the Headers we use are 304 stainless and we don't coat them because it's really not necessary. Underhood temperature has never been an issue.
Seth
Old Dec 2, 2009 | 07:58 PM
Sparo2's Avatar
Sparo2
Mine are made of 304 stainless as well with 1-3/4" primaries. I never have problems with unhood temps.
I would go with 1-3/4" headers if i were you. If you're going to be digging into the engine or adding a power adder then go bigger.
To Headers Question
