How much abuse??
Old Dec 5, 2009 | 12:24 AM
SpecialSause's Avatar
SpecialSause
Default How much abuse??
How much can the Stock 05 diff take? If I'm on tires that are a little more sticky than stock with my car being completely stock how much do I have to worry about it breaking while launching it, say from like 2k or a little more?
SS
Old Dec 5, 2009 | 01:05 AM
bps999's Avatar
bps999
I would think the greatest danger would be from wheelhop, which can definately happen. Maybe try to abort launches that hop... Though at the strip you only get so many runs and throwing one out can be hard...
Old Dec 5, 2009 | 12:31 PM
CMY SIX's Avatar
CMY SIX
first question, as shown on this forum NOT MUCH!
Old Dec 5, 2009 | 01:11 PM
NYC6's Avatar
NYC6
The 05 rear is a weak link. It was beefed up for 06 due to many breakages of the 05 unit. It wont likely take sticky tires for to long.
Old Dec 5, 2009 | 02:08 PM
saplumr's Avatar
saplumr
This is the result of NO wheelhop and runflats.
Old Dec 5, 2009 | 03:15 PM
SpecialSause
That is awful... Will GM not do anything to fix this for the 05's or am I on my own?
Old Dec 5, 2009 | 03:17 PM
saplumr's Avatar
saplumr
Sorry...you're on your own. If it happens put a Z06 diff in.
Old Dec 5, 2009 | 03:18 PM
SpecialSause
Since it's a 2005 wont i need to change the adapter plate on the back of the transmission also?
Old Dec 5, 2009 | 03:24 PM
saplumr's Avatar
saplumr
C6 Z06, not a C5. You will have to change the trans output shaft though. You can go with the updated C6 diff for cheaper if you plan on keeping the hp down.
Old Dec 5, 2009 | 03:25 PM
SpecialSause
Thanks for all the help. I better save up for a diff before I start modding anything power wise.
Old Dec 5, 2009 | 05:12 PM
SpecialSause
Instead of buying a new differential would a brace like this:
http://www.dynotech-eng.com/dte_c6_diff_strut.htm
be enough to be able to not have to worry about breakage in a stock application? And if I were to buy this how much more could it take than stock, if any?
Old Dec 7, 2009 | 09:52 PM
SpecialSause
Is the brace a waste of money or what??
Old Dec 7, 2009 | 10:36 PM
saplumr's Avatar
saplumr
The brace won't stop the destruction. But if you keep your car stock and no wheel hop it may never happen.
Old Dec 8, 2009 | 11:53 AM
quickc6's Avatar
quickc6
Do you have a manual or auto trans ? The manual trans are a lot harder the rear end than the auto .
Old Dec 8, 2009 | 12:34 PM
mittens's Avatar
mittens
I have an 06, stick car, and i am worried about breaking mine. been a ***** at the track so fare, nothing over 2000-2500 launching on some sticky drag radials.
how much can these handle?
Old Dec 8, 2009 | 06:09 PM
Robls6's Avatar
Robls6
If you're afraid of breaking it and don't have the money for a replacement diff just drive it easy and stay off the track. I broke the output shaft off of my 07 MN6 and almost trashed the diff from all of the pieces of the output shaft swirling around in the diff. It cost me almost $4000 to get back on the road with an RPM Stage 5 trans and hardened axles in the diff while everything was apart. You gotta pay to play... A&A blown 07 coupe 570RWHP
Old Dec 9, 2009 | 01:59 AM
SpecialSause
Not to seem cheap but I did pay and I'm sure you see my annoyance with trying to play with a stock car that can't hold up to its stock horse power and torque.. this is just venting though, thanks guys for all the answers.. This forum is great.
Old Dec 10, 2009 | 05:15 AM
Restroom's Avatar
Restroom
Part of the fun of owning your own car is being able to conduct your own empirical tests to figure out exactly what the answer you're looking for is. The cool part is that no matter how many of us give you whatever guesses, lies or circumstantial evidence we feel like, not one of us could possibly predict how much abuse YOUR diff'll take. You only get a few lousy years on this planet, most of which will probably go by without a 'Vette in your garage. Go on and blow the damn thing up, as long as you have fun trying and don't blow it up in my driveway. What's the worst that could happen?
/my money's on something else failing on the way to finding out
Old Dec 10, 2009 | 09:43 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I've been told the strut won't prevent your dif from cracking but it may help prevent further consequential damage.
I think under 'normal' use has some bearing on your complaint. Virtually any product can be abused...pushed beyond its design specs. These cars aren't necessarily designed to withstand high RPM drops off the line with sticky tires. If you want the car to do more than it was engineered and built for you have to be willing to bear the consequences (or make modifications which may help prevent failures for how you're using the car).
To How much abuse??
