Help with tire.
Old Dec 5, 2009 | 06:34 PM
RULEMKR's Avatar
RULEMKR
St. Jude Donor '09
Default Help with tire.
Anyone have any idea why it would be difficult to put air in a tire? I seem to have to push extremely hard on the tire stem to get the air to go in. They did not use to be this way; although I did have tires replaced
back in September.
Old Dec 5, 2009 | 06:39 PM
glass slipper's Avatar
glass slipper
back in September.
There's a "square" o-ring in the valve stem cap that sometimes remains on the valve stem when you remove the cap. If that's what happened, it will be very difficult to push the air chuck on far enough to get air in. The o-ring may also be stuck in the air chuck. Those are the easy things to check for so we'll get them out of the way first...check back if that's not it.
Old Dec 5, 2009 | 06:46 PM
RULEMKR's Avatar
RULEMKR
St. Jude Donor '09
Thanks; I will definitely check that as soon as I arrive home.
Old Dec 8, 2009 | 02:32 PM
RULEMKR's Avatar
RULEMKR
St. Jude Donor '09
Just got around to checking air stems and all the o-rings are present and accounted for.
Old Dec 8, 2009 | 03:32 PM
autoxnut's Avatar
autoxnut
My guess would be a damaged valve stem core which is easy to screw out and replace. Had this happen on a tire of mine once.
Old Dec 8, 2009 | 03:55 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
all 4 tires are difficult to fill?
Old Dec 8, 2009 | 11:13 PM
RULEMKR's Avatar
RULEMKR
St. Jude Donor '09
I will try this next.
Thanks for the advice. Are they just regular stems?
Old Dec 8, 2009 | 11:15 PM
RULEMKR's Avatar
RULEMKR
St. Jude Donor '09
No just 2 of them.
To Help with tire.
