How to remove axles from diff?
Old Dec 5, 2009 | 08:58 PM
vetracer's Avatar
vetracer
Default How to remove axles from diff?
I have the rear of my car out and need to know how the axles come out so I can remove the differential. The service manuals make it sound like they just pull out but that doesn't seem to be the case. I don't want to pry them and damage them:
Also does this sound like a lot of play with the car in nuetral?
http://http://www.youtube.com/watch?v=exdCG5HiXsY
I am changing the converter and want to get the diff checked out. It seems to have a lot of noise and slop in it when shifting into drive or reverse when parked.
Thanks in advance
Old Dec 5, 2009 | 09:22 PM
65_mutt's Avatar
65_mutt
I just went through all that with my 05 - I was able to yank mine out fairly easy - but I thought the manual said to use a prybar to help seperate them from the diff. Shouldn't hurt anything if you don't get crazy and keep it off the seals.
Old Dec 6, 2009 | 12:32 AM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Thanks in advance
You have to use a pry bar but in a swift motion. When you do that they'll pop out enough for you to pull them out the rest of the way with your hands.
Old Dec 6, 2009 | 07:37 AM
Fast06Z06's Avatar
Fast06Z06
They have a small retainer clip that just requires alittle force with a pry bar to "pop" once they do they just slide out.
Old Dec 6, 2009 | 10:46 AM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
give them a tug - it won't hurt them.
Old Dec 6, 2009 | 11:28 AM
vetracer's Avatar
vetracer
Thanks everyone, I'll give it a try.
*Update* It worked, so simple I couldn't believe it
To How to remove axles from diff?
