Hurst Billet Plus
Old Dec 6, 2009 | 12:24 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Default Hurst Billet Plus
Just installed. Purchased from a member like new. Whisper quiet. 6500rpm's no noise period. Just a click for each gear change. Very heavy duty 35 percent short throw. Love it. This will quicken things up. No pictures but it's stock look. With the stock **** and height. Was worried about noise so. I put the first
rubber on, Then the second fits into the first. So I wrapped 3/4 wide 3m insulation. Till it was as thick as the stock stick tucked it level
with the rubber as I went. Worked so perfect.The quick shift allows better boost with a faster gear change. Time for a cruise!
Old Dec 6, 2009 | 12:49 AM
SpinMonster's Avatar
SpinMonster
I love when you find a part you really want or need like this for a good price. Shifters dont wear out in normal use so its likely the most fun upgrade you can do.
Enjoy.
