160 Thermostat
Old Dec 9, 2009 | 01:14 PM
CFR5's Avatar
CFR5
Default 160 Thermostat
I understand what these actually do, allowing the engine to run at a lower temp, but what performance gains does it actually yield. Basically, is it worth the $30 or so if I just have bolt ons (headers, catted x-pipe, and exhaust)? Thanks
Old Dec 9, 2009 | 02:51 PM
C2C6Z06's Avatar
C2C6Z06
St. Jude Donor '08-'09-'11-'12
From what I have been told, the lower t-stat allows the engine fans to be set lower resulting in a cooler running engine. That keeps the ECM from pulling timing as the temps increase. Pulled timing=less performance.
I would venture to say the $30 with all the add ons, is a definite move.
Old Dec 9, 2009 | 07:18 PM
Bill Dearborn's Avatar
Bill Dearborn
All that may be true but the engine will not pull timing when running at the stock thermo temperature setting. When you are driving on the highway the car will run very close to that temp setting even in very hot weather. In traffic the stock temps will go up to the range of 240 degrees. Maybe some timing is pulled maybe not but who cares? You aren't going anywhere anyways. If you are tracking the car the temps will approach 230 degrees when running at wide open throttle for 20 to 30 minutes at a time. No matter which thermostat you have in the car it will reach those temps as the cooling system performance is the limiter not the thermostat. I have never installed a lower thermo and have never noticed any difference in performance when running with other cars that have them.
Bill
Old Dec 9, 2009 | 07:47 PM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Default Cooler temps recipe
Cooler running engines produce less heat=less friction heat transfer. If you're really interested in cooling down your engine, you may want to try a hi-capacity radiator, 160* stat, and an electric water pump.
I run a DeWitts hi-capacity radiator, 160* stat and Mezziere electric water pump. The combination of these together pumps a greater volume of coolant, and pumps it at a continual pace with cooler running temps as a result. My average running temps ran to 225* in heavy sustained traffic and 205-210* in ordinary summer driving in stock configuration. After the switch, my average running temps run 160-180* and sitting in heavy sustained traffic, never gets above 190*. That's a dramatic change and I'm totally pleased with the outcome and performance.
Old Dec 9, 2009 | 07:52 PM
oneblackvette's Avatar
oneblackvette
just a dewitts and fan reprogram will yield temps less than 200 max for street driving. Track is a whole other matter.
Start with the fans then see where you are at. The factory radiator is pretty small when dealing with extreme heat in the south.
Old Dec 9, 2009 | 08:50 PM
Ragtop 99's Avatar
Ragtop 99
All that may be true but the engine will not pull timing when running at the stock thermo temperature setting. When you are driving on the highway the car will run very close to that temp setting even in very hot weather. In traffic the stock temps will go up to the range of 240 degrees. Maybe some timing is pulled maybe not but who cares? You aren't going anywhere anyways. Bill
Timing can get pulled before that temp. Additionally some of that underhood heat transfers to the air intake and it does not take much increase in intake air temp to pull timing. This all assumes a stock car. Now assume the car has mods and is tuned for better power. It will be more sensitive to high temps and give back some of the timing and power if temps creep up over 200*.
IMO, the 160 T-Stat is not worth much if the car isn't tuned, especially the fans, to take advantage of it.
Old Dec 9, 2009 | 11:04 PM
CFR5's Avatar
CFR5
I will be getting my car tuned once I get the headers installed. On the other side, this is my daily driver and I do not plan to track it. Am I getting the right feeling so far that the thermostat would not be necessary/advantageous? Thanks for all the input so far.
Old Dec 10, 2009 | 09:25 AM
6Speeder's Avatar
6Speeder
If all you do is cruise, stay stock. BUT, you say headers and a tune are in your future. If you are looking for more performance, a lower temp thermostat is part of the basic mods you should add. As said by others, the ECM pulls timing (and therefore horsepower) at temps (AIT and ECT) that you will face with the stock thermostat. It's a no-brainer.
To 160 Thermostat
