C6 headlight lense
Old Dec 9, 2009 | 09:13 PM
samanatoo's Avatar
samanatoo
Cruising
Default C6 headlight lense
Just recieved my new 09 Z06 was wondering if there is anyway to remove the headlight lenses to clean inside them. I can see a dirt film on the inside, thanks
Old Dec 10, 2009 | 01:26 PM
LKicklight's Avatar
LKicklight
Default Bugs/Dirt
Like I was told, if there is anything inside the headlights, then its defective..the unit is suppose to be sealed and nothing should get inside. I have dead bug in my right light...taking to the dealership next week.
LKicklight
Dallas, GA.
Old Dec 10, 2009 | 05:52 PM
dkrhardy's Avatar
dkrhardy
They aren't sealed. You cannot take off the lens. Try a shop vac through a bulb hole to get the bug out. Just place the hose close to the hole and I bet the bugs comes out.
Old Dec 10, 2009 | 07:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree!! If your light is defective,,,,let the dealer replace it!
Other wise,,,your living with it! At least document the issue. if something gets worse in the future,,,your covered!
BC
Old Dec 10, 2009 | 10:40 PM
samanatoo's Avatar
samanatoo
Cruising
I will take it to the dealer when I get a chance. It does not look horrible just alittle dirty when lights are on or in the garage with the flourecent lights on.
Old Dec 11, 2009 | 12:42 PM
85Z514+3's Avatar
85Z514+3
I believe that is normal. You are probably seeing what appears to be a light film on the inside of the housing. My 07 has had this from day one. Even my 02 TrailBlazer has the same thing and it has not changed in over 7 years. I do not think any of them will be completely crystal clear. Just my 2 cents.
Old Dec 11, 2009 | 08:35 PM
luv2golf's Avatar
luv2golf
I'm going to take mine in, one of them get condensation forming on the inside on cold days.
Old Dec 11, 2009 | 09:16 PM
dkrhardy's Avatar
dkrhardy
golf guy - condensation is normal, I don't think you'll get much from the dealer.
Old Dec 12, 2009 | 03:03 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
LKicklight
Dallas, GA.
Old Dec 12, 2009 | 10:50 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
I would raise some cain about an 09, 08 for that matter with lens problems.
You'll have not much to any luck with the lights under warranty and out of warranty forget about it.
THe lights are not sealed air tight. Condensation is normal and bugs and crap can get in.
You can take them apart but if you have never did it you'll most likely ruin the lens in the process or end up with a crappy job.
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
Old Jan 24, 2010 | 05:03 PM
jmmy's Avatar
jmmy
My book says condensation is normal with light off. When on, heat drives out the moisture. The housing is vented and this'll happen when air moves in and out.
To C6 headlight lense
