Rim width question
My question is, will a 10.5 in rim fit in the back of a C6 without any modifications? I know the stock 19 in rim is 10 in; not sure if that extra half inch along with the tire will create any issues with rubbing.
Also, if anyone has the NT555RII setup and has been caught in the rain, how did they perform?
Thanks for any help you guys can provide.
Adam
Adam
Try the sizes; http://www.1010tires.com/TireSizeCalculator.asp
You'll also have to look at the offset of the 18" wheel, changing from stock offsets can cause problems. Try;
http://1010tires.com/WheelOffsetCalculator.asp
A better way (that will cost more of course) is to start with an front 18x8.5" wheel and widen it. This wheel starts with a 56mm offset and sticks out 2.55". There is room to the inside to add a full 2.0". If you want the wheel out a little farther you can start with a 9.5" wheel (w/54mm offset) and add 1.5-2.0" to the inside and it will fit.
I'm running a 17x11.5" rim on the rear of my C6 that was widened in this way starting with a 17x9.5" wheel to fit 335x35x17 Kumho 710s.
--Dan
