Hello all i just bought an 05 M6 Z51 with navigation and i set up all my radio presets and adjusted the clock to the proper time and every time i turn the car off and then back on it resets all my presets and changes the time. Has anyone else ever experienced this issue or maybe know what may be causing it?
After you have done your setting if you have the number 1 FOB press and hold the number 1 button in the driver door until it bleeps and it should keep your setting.
That worked for the radio stations but not the clock, it keeps adjusting to a different time zone. I set the clock to the correct time and then i pressed and held 1 on the door till it beeped. I then turn the car off and back on again and it keeps the stations but the wrong time, am i not doing something right or could it be a software issue?
