Starting/Charging sytem problem finally FIXED!!
Old May 26, 2010 | 01:30 AM
GregC6's Avatar
GregC6
Originally Posted by cranky
JEGS.COM has them for about 25.00. i install them on every header installation i do. works great !!!
http://www.jegs.com/webapp/wcs/store...94955412&Nty=0
which one would you recommend so it fits nice?
did you wrap your alternator cable too? seems like the black plastic wire loom is slowly melting
do you think this would be a better solution?
http://www.jegs.com/i/Thermo+Tec/893/14003/10002/-1
Old May 26, 2010 | 08:29 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I made my own out of foil backed high temp canvis and some nylon pile industrial insulation. Mads one for the starter and AC Compressor.
BC
Old May 26, 2010 | 10:47 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Good stuff here. I wouldn't mind having a schematic of the c6 Voltage regulator although you can use the corrolation from the C5.
Old Jun 2, 2010 | 02:41 PM
GregC6's Avatar
GregC6
I am gonna order the heat blanket for the starter tonight and I was wondering is it possible to put it on without using a lift or a jack?
This is the one I am getting
http://www.summitracing.com/parts/DEI-010402/
