C6 Battery Changing Procedures
Old Jan 3, 2010 | 08:57 PM
Suite C6's Avatar
Suite C6
Default C6 Battery Changing Procedures
My battery on my 05 C6 finally began to lose charge after 5 years and I wanted to know if there are any specific procedures to disconect and re-conect the battery. I plan on purchasing a new battery but don't want to fry anything in the process of exchange.
Any sugestions and precautions would be appreciated,
Suite C6
Old Jan 3, 2010 | 09:27 PM
Andy 53's Avatar
Andy 53
I just replaced the battery in my 05 recently. I did not take any special precautions...however...be sure you have the key fob close by when you connect the new battery. The alarm went off as soon as the power was connected!
Andy
Old Jan 3, 2010 | 09:31 PM
seevi's Avatar
seevi
My battery is about 3.5 years old and it has just recently started losing power. I left the car for Christmas vacation and it wasn't driven for 8 days. Wouldn't start! Connected a small battery charger for and hour and a half and the car started without difficulty. left it for four days in the coldest weather the car has ever experienced and it wouldn't start. Placed it back on the charger for 6 hours and the car started. I believe the car just needs to be driven.
In your case, I would just follow the directions in car's manual.
Old Jan 4, 2010 | 12:40 AM
CO Lightfoot's Avatar
CO Lightfoot
Be careful not to drop an irreplacable washer/nut/bolt into an irretrievable place... I hate it when that happens.
Old Jan 4, 2010 | 11:12 AM
GotVett?'s Avatar
GotVett?
Mine went dead while doing my last mod. However, I did recharge it and has been fine ever since (about 4 or 5 day's now). I'll probably be needing one myself not too long and those suckers are heavy and awkward to get out and put back in.
Old Jan 4, 2010 | 02:37 PM
mike72's Avatar
mike72
make sure to fully charge the new battery before hooking it up. The alternator was not meant to recharge a low battery but to maintain a charged one.
Old Jan 4, 2010 | 03:11 PM
Suite C6's Avatar
Suite C6
Thks everyone for your input.
Suite C6
Old Mar 18, 2010 | 11:44 AM
cclive's Avatar
cclive
This is sure good advice...how many times have we heard about this problem on this forum.
Old Mar 18, 2010 | 01:12 PM
MachAll 2005's Avatar
MachAll 2005
Let's see ..... every time you start your car, your battery is suddenly down on charge ...... IF you have enough power in your battery to start the car, the alternator will bring it back to full capacity if you drive it long enough.
Old Mar 18, 2010 | 01:26 PM
TXC6Z51's Avatar
TXC6Z51
Yes, but it is extremely hard on the alternator. Just because it will do it doesn't mean it is good for it. I always put a new battery on the charger before I install it. I've seen several alternators go out in from having to run full tilt to charge a dead battery.
Old Mar 18, 2010 | 01:35 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Although its OK to disconnect either one of the cables first, I always remove the negative first. That's just in case the wrench accidently touches a ground in the process.
When I was about 20 years old, I was disconnecting the positive cable on a battery first and the wrench touched a metal part which happened to be grounded. It caused a spark and the battery exploded throwing acid everywhere. Ever since then, I always disconnect the negative first.
You will have to re-index the windows, which only takes a few seconds.
To C6 Battery Changing Procedures
