are gears worth it
Old Jan 5, 2010 | 12:13 AM
ls3yeager's Avatar
ls3yeager
Default are gears worth it
i currently have a cam only ls3 and was thinking about changing my gears. i just dont know if its realy worth the expense. can someone please tell me how much they picked up and with what gears. i would realy like to know before and after e.t and also mph. thanks for all the help guys.
Old Jan 5, 2010 | 12:22 AM
HANNY's Avatar
HANNY
from what i have seen it helps get the times down,,,some other might give some times out. I'm considering gears and for me A6 trans.) convertor
Old Jan 5, 2010 | 12:36 AM
3 Z06ZR1's Avatar
3 Z06ZR1
I went with 390's with the base transmission. Worked out great
still plenty high for highway with the .050 6th gear.
But also just right for my needs even with F/I. If your a Z-51
your already lower in the transmission. Some guys love the 410's.
LS1LT1's Avatar
LS1LT1
are gears worth it
Yes.
Even in an otherwise stock manual C6, gears (3.90s or 4.10s) are awesome but in a cammed car such as yours they should almost be a mandatory mod.
Old Jan 5, 2010 | 12:45 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Originally Posted by LS1LT1
Yes.
,,I have gears and a 2800 stall and it's awesome!{A6}
Old Jan 5, 2010 | 01:46 AM
GotVett?'s Avatar
GotVett?
I'd like to go 4.10's next.
Old Jan 5, 2010 | 01:59 AM
Sparo2's Avatar
Sparo2
How much time do gears typically shave off of the timeslips?
Old Jan 5, 2010 | 09:01 AM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Default Gears for lowered times
Old Jan 5, 2010 | 09:06 AM
Finster07's Avatar
Finster07
I went with 3.90's with the base transmission. In hindsight since I do very little highway and remain in town, the 4.10's probably would have been a better choice. But, Im here to tell you I felt the difference between stock 3.42's and the 3.90's. You didnt say anything about if yours is an auto, mn6, or Z-51. There are a ton of threads here about gears, do a search. Spinmonster has some excellent posts regarding gears and the 1/4 mile times.
Old Jan 5, 2010 | 09:09 AM
johnodrake's Avatar
johnodrake
Moderator
I like mine. I don't drag race because it is a Vert. 6th gear is a good highway gear now.
Old Jan 5, 2010 | 09:46 AM
White_Lightning's Avatar
White_Lightning
is your car a z51 car? IMO doing gears in a z51 car really shortens 1-3 way to much,
the top mph in 1-3 on a Z51 car is almost the same as a base coupe with 3.90s..
Old Jan 5, 2010 | 12:37 PM
ls3yeager's Avatar
ls3yeager
My car is a manual and is not a z51. Would really like to know how much peple are picking up at the track.
Old Jan 5, 2010 | 02:38 PM
LS1LT1's Avatar
LS1LT1
A lot will depend on traction (use of drag radials/slicks) and driver's skill but typically the switch from 3.42s to 4.10s can result in a .2 to .4 reduction in ET with notable gains in trap speed as well.
Old Jan 6, 2010 | 10:33 AM
ls3yeager's Avatar
ls3yeager
thanks for the help... i cant believe no one has ran there car before and after gears to give us all a good answer. even if u dont know the e.t. and mph but you raced someone before and after if u can atleast say it picked up so many lengths that would be a lot of help
Old Jan 7, 2010 | 03:09 AM
PRE-Z06's Avatar
PRE-Z06
I gained ~.3 and 0mph in the 1/4 w/ the addition of 4.10s which required an extra shift...I had the mn6 and could run 3rd out to the traps w/ 3.42s, now it's right at the top of 4th...if you're already hitting 4th, then you'll likely gain .4 and 2mph b/c you won't be adding a shift...ie I gained all the ET in the 1/8 and ~2mph because before I was just getting into 3rd and after the gears was at the top of 3rd...They make it easier to launch and will really help your 60'!
To are gears worth it
