I'm at wits end
Old Jan 6, 2010 | 05:25 PM
Boomer111's Avatar
Boomer111
Default I'm at wits end
Have exhausted my research into small cam for 08 MN6 LS3. Now I have looked into DTE gear change to 4.10's. Be about the same $ with UD pulley added to cam install. Might as well add the C5R chain while it's is apart. Tuner feels the chain swap isn't needed by the way.
It is one or the other mods right now maybe last mod too.
422rwhp/tq motor. No track or strip planned or light to light pulls. Generally drive low rpm's but on occasion will find a nice back road and have some fun.
If I go DTE whick stage? Can I get by with stage 1 Tuner recommends stage 2, hell if I go stage 2 might to stage 3 and get both oushafts upgraded for another 250$. ( It never stops does it ). Any way I really can not decide which mode to do and if I go the gears which stage will suffice?
Looking for guys that have had the same problem for some input. My head actually hurts from all this. HELP
My thinking with the gear change was that it would be more fun all the time whereas the cam only under 3 to 5 grand pulls. Also I run Invos 305 in the rear so maybe the rear end change would be the more reliable mod. Hell I really don't know.
Old Jan 6, 2010 | 06:23 PM
Wass's Avatar
Wass
St. Jude Donor '09-'11
I have both mods, 4.10 gears & cam. I wouldn't want to part with either of them, and I think one compliments the other. However, I went with gears first, then headers & CAI, then cam with dbl. roller T.C., UD pulley, comp 921 springs, etc., and finally a ported Fast92 (Spinfast). All of this over a two year period. That worked well for me. Good luck with your decision!
Old Jan 6, 2010 | 07:07 PM
Boomer111's Avatar
Boomer111
I did talk with DTE, Jenny, was very helpful explaining that I visited an old Web page. The New Stage 2 has Z06 output shafts both sides and a carbon disk pack. So my decision would be Stage 2 for the gear change. Now cam or gears?
Old Jan 6, 2010 | 09:19 PM
jmudreamvette's Avatar
jmudreamvette
Take a ride in a cammed car and a ride in a gear only car. For me if I had the money I would go with a cam change first. Cam is coming at the end the year for me. either one will be good, but a gear will be insurance when you do the cam next! It never does end....
Old Jan 7, 2010 | 02:46 AM
PRE-Z06's Avatar
PRE-Z06
I hate to say it too, but they really go hand in hand...if I only had the money to do one, I'd go with the cam as long as it was a small one as you talked about, because you won't loose as much bottom end and your 305 invos aren't gonna hold after a gear change
Old Jan 7, 2010 | 08:15 AM
Boomer111's Avatar
Boomer111
Helpful, thank you!
Old Jan 7, 2010 | 07:15 PM
Boomer111's Avatar
Boomer111
Just to update..........I went with the Stage 2 rear differential. Like the idea of being above the drone zone at 70mph and seems like I would experience the gear change more than the cam. Also I always have thought the C6 is a little to long legged. Not DD so around town should be fun and I see no significant drawback on the open hiway.
Old Jan 8, 2010 | 06:44 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I've done it all twice now. Second time I went gears first. Gears you feel every time you hit the gas. Plus the cam has downsides...there are no downsides to the gears. You made the right choice in my opinion!
Old Jan 8, 2010 | 07:16 AM
99FRC Newb's Avatar
99FRC Newb
cam. my cam made me MUCH happier than my gears did
Old Jan 8, 2010 | 08:28 AM
Boomer111's Avatar
Boomer111
This is what I was thinking too.
Old Jan 8, 2010 | 08:42 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
While you're putting the diff in, put in a lighter weight flywheel.
Old Jan 8, 2010 | 04:42 PM
Boomer111's Avatar
Boomer111
Any down side for this?
Old Jan 8, 2010 | 04:59 PM
Ragtop 99's Avatar
Ragtop 99
You may need to tweak the idle and very low rpm (e.g. 600 - 1000 rpm)airflow settings. When I had a light weight flywheel I used a couple hundred rpms higher launch. Since your car will launch harder with the gears, you'll adjust to the feel at the same time as you get use to the gears.
For light to light, gears were the right choice. I have the DTE Stage II also.
Old Jan 9, 2010 | 08:49 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Not a big money saver to do it now....you can swap the diff without pulling the trans, mid pipes, etc.. It's not like the flywheel is right there, you have a lot of work to get to it. So it's a lot of work to swap just a flywheel for very little gain - maybe 10 on the dyno.
For bang for your buck mods, a light flywheel is way down on the list. Most do it if they replace their clutch.
Going on a diet and losing 20 lbs would have a much better benefit and be a lot cheaper!
Old Jan 9, 2010 | 09:10 AM
Boomer111's Avatar
Boomer111
Howd you know I needed to lose 20lbs? After turning 60 the weight seems to want to hang around more. And yes I already work out an hour every day have for 40 yrs. No weights mostly cardio and calisthenics.
Old Jan 9, 2010 | 09:42 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I'm the VP at this business...www.pritikin.com so my business is people who could lose 20 lbs!
You are in good company. Most of the world is in your shoes.
Old Jan 9, 2010 | 12:10 PM
Boomer111's Avatar
Boomer111
By the way how is your weight? JK
To I'm at wits end
Old Jan 9, 2010 | 12:18 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
180, same as high school. 10 years ago 230!
Old Jan 9, 2010 | 01:21 PM
SpinMonster's Avatar
SpinMonster
99% of the people out there that say what you are saying here about higher RPMs, all had the flywheel changed with a new clutch. The lighter flywheel doesnt require anything different with launch rpms, the clutch does. More aggressive clutches need higher rpm's to get going smoothly or you chatter.
On my car, I added the fidanza Al flywheel to the LS7 that was already in there an I dont even need to touch the gas pedal to get going.
Agressive clutches are what makes for more RPMs being needed.
One important thing to note is that your average clutch is 15 pounds lighter than an LS2 or LS7 clutch so if you get a SPEC 3 or Tex 700 clutch with the steel flywheel its nearly the same weight as an LS7 with the aluminum flywheel so the argument about weight differences is moot. A guy running a Tex with a steel flywheel is running 15 pounds lighter compared to 17.5 off from using the al flywheel with the stock clutch. Some of the twin discs weigh even less at only 39 pounds and none of them report bogging.
Old Jan 9, 2010 | 02:52 PM
Boomer111's Avatar
Boomer111
Ya good job.
