Fuel Pump Replace
Last week, I got my car back from garage after they replaced leaking seals on gas tanks which they had removed about 2 weeks ago to fix / replace the fuel sending unit which had quit working (fuel guage on dash would quit after tank reached halfway mark). This is second time fuel sending unit has needed replacing.
When I dropped the car off two weeks ago to have the fuel sending unit fixed, the fuel pump was good. After picking up the car, engine trouble light came on indicating an emmission problem which turned out to be the leaking seal on the gas tank.
When I dropped off car last week to fix the leaking seal, the fuel pump was working fine. When I picked up the car last Thursday morning from the shop after seal fixed, I drove it to work. Come out after work, push ignition switch, and bad noises come from under the hood. Now garage service advisor tells me the fuel pump needs replacing which he says is a separate problem from the fuel sending unit (I paid $200 deductible under extended warranty) and separate from leaking seal problem (which dealership garage fixed at their cost). They want me to pay another $200 deductible as he says the fuel pump problem is not a result of anything they did previously (although they've taken the gas tanks off and on about 5 times). Like I said, the fuel pumps were good before and coincidentally went bad same day I picked up my car, got into it with car already running when car attendant pulled up, drove to work, came out and that's when the under-the-hood banging started.
What do you think? Normal for fuel pump to need replacing at 35,000 miles? Possibly something garage did when they had fuel tanks off and on while repairing fuel sending unit and repairing emissions / tank seal leak? Interested in your thinking.
Thanks.
It's bad enough that they're so incompetent as to have to redo things several times, but when they try to BS you to cover thier own a$$ at your expense, its time to go and report the incident...As a former service writer, I wouldn't have dared to try to charge someone for a fuel pump when I knew I had a mechanic in there several times. It's way to coincidental to even try to justify, they're treating you like a chump!
It would be a different story if they replaced your spark plugs and then the fuel pump went out (dealers have to deal with those kind of people all the time too, nothing like having a customer say their radio went out a week after you did a brake job and its your fault)
In your case I am surprised the dealership did not step up and take care of it. The fuel level sender went out in my 06 Trailblazer SS at 45K, you could buy it separate from the fuel pump sending unit. I have not replaced the fuel pump or fuel level sender in a C6 yet so I couldn’t tell you if it comes as an assembly only or if you can buy the sender separate from the pump. My 2005 C6 just rolled 60K with no fuel pump issues, my coworkers 2006 C6 just rolled 14K and needed a fuel pump. It all depends on if it was a good day at supplier or not…
IF you buy the sender separate then it comes with just the wire clips; you have to pull the old sender's wires out of the connector and put the new ones into the old connector. IF you buy the whole module it just drops in.
Having done the job myself, it is REAL easy to screw up the install, and you have to get it just right otherwise the car isn't happy. Especially the little plastic transfer lines in the tank. When you put one (or both) tanks back in the car you have to be careful of all the little seals and emissions connectors so you don't get a leak. There are 2 (a green and a yellow) O-Rings on the big stainless steel bitch (crossover pipe), that are VERY easy to cut when you're removing or installing the crossover pipe since it is under alot of tension with the tranny still in the car.
There are several places where you could get an emissions leak if the tanks have to come out; there are 2 connections on the filler tube; the main rubber filler hose, and a small plastic emission line that connects to the filler housing where you insert the fuel nozzle. There is a plastic crossover line that connects both tanks, and sits above the big stainless crossover pipe. Lastly there are 3 plastic lines that connect to the carbon canister. If any of these break or have broken connectors you run the risk of an emissions leak. And the car WILL know. Also (this happened to me) even if you re assemble everything perfectly you'll still throw an evap emissions code because the wiring harness connector has oxidation inside it and so reports an out-of-spec value. Because of this I would recommend anyone doing the job to plug-in and unplug each of those connectors 5 or so times just to ensure a good electrical connection.
And change the brand of gas you use. 2 sending units in 35k speaks of a gasoline problem.
Good luck!
Also, you have to be real careful installing the pump modules with senders and the attached plastic transfer lines. It would be real easy to damage the delicate sender card during the process.
The way I see it there are really 2 reasons to do the job yourself:
1. Can't afford (or don't want to pay) someone else to do it.
2. Want to learn about the car.
