Will cometic head gaskets leak coolant ??
Old Jan 12, 2010 | 11:57 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default Will cometic head gaskets leak coolant ??
Just had a discussion w Engine Builder about using the TF 225's I'm ordering w 61cc chambers using a .040 COMEDIC to achieve a CR of
around 11.5: 1. He said absolutly not. They will leak coolant in a short time and insisted the .051 OEM is the way to go w/o ARP Head bolts.
I was stunned at this because I thaught optimal QUENCH area was what
would be needed to get the most out of my setup w a 232 CAM currently
yielding 461 RWHP and looking to get to 500 RWHP employing the TF'S.
Are there any members having coolant leaks or other problems with the COMEDICS. Where am I going wrong ?
Old Jan 12, 2010 | 12:05 PM
SpinMonster's Avatar
SpinMonster
I've never not used them and I never had a leak.
If his last try with them was a long time ago, he is out of date on info. He may also have used them on a non-ls engine and they may have had irregular deck surfaces. Many inferior mills on heads would have grooves that can cause leaks. Trick Flows are not bad mills.
Old Jan 12, 2010 | 12:52 PM
wazslow's Avatar
wazslow
They work great, just need very flat smooth head and deck surface!
Old Jan 12, 2010 | 01:00 PM
LSCHLEM's Avatar
LSCHLEM
I never heard of anyone having leaks with comedics. I do believe it was a while back when he came to that conclusion and those things stay in the brain. BTW the builder did not think the 232 cam was a good choice and
said I would be lucky to see 435RWHP. A good MECHANIC but not a DYNOTUNER .
AM I on target using 61CC TF's w .040 COMEDIC to arrive at a CR of 11.5 ?
Old Jan 12, 2010 | 01:07 PM
silver93vert's Avatar
silver93vert
I've used .045 Cometic's with my 62cc TFS 225's for the last year without issues.
Old Jan 12, 2010 | 01:10 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I have seen a few external leaks from Cometic gaskets and stopped using them, it was a while ago though, maybe they rectified the problem now. Good luck on your build!
Old Jan 12, 2010 | 01:19 PM
LSCHLEM's Avatar
LSCHLEM
Originally Posted by silver93vert
I've used .040 Cometic's with my 58cc TFS 225's for the last year without issues.
Glad to hear that. Your Sig says you got 62ccTF's W .045 COMEDIC for 11.7 CR. WITH 58CC & .040 COMEDIC you are probably at 12.00CR
Old Jan 12, 2010 | 02:37 PM
bowtiguy's Avatar
bowtiguy
I had a Cometic head gasket leak on my LS7. Gaskets were .51 thickness and we used ARPhead studs.
BUT
I later found out that my #4 liner ( Darton resleaved block) had dropped .001" allowing combusting gas's into my coolant system.
Took me 3 head gasket swaps to find it out. The last swap we used stock GM gaskets.
If you compare the two side by side the stockers appear to have more material on them. If you do not need a thinner gasket..I'd stay stock.
Also remember, if you use any fastener than stock on the heads, you "should" be doing your final hone using those fasteners.
I now use ARP head stauds and STOCK GM gaskets with a 65CC combustion chamber on my latest build.
good luck.
Old Jan 12, 2010 | 03:37 PM
tjwong's Avatar
tjwong
A lot of the issues concerning leaks with Cometic gaskets is not with the gaskets themselves but with block and head surface preparation. If the surfaces are not righ then you can incur leaks. For extra insurance I always copper coat the gaskets even though Cometic says no sealants are to be used with their gaskets, doing this and insuring that the surface prep is correct I have never had one leak. Except once when a customer supplied a set of ARP bolts that worked loose because they were not retorqued after a few heat cylcles.
Old Jan 12, 2010 | 04:10 PM
SpinMonster
I've pretty much heard enough. Lose this tuner/engine guy.
A 232 cam (not optimum) will make about 490rwhp with trick flow225's and a FAST. A 234 cam I have will break 500rwhp (closer to 510rwhp)
A 232 cam makes near 455rw with a FAST without changing heads.
Old Jan 12, 2010 | 04:22 PM
silver93vert
My sig is correct...I had 58cc heads on my mustang Oops
Old Jan 12, 2010 | 06:12 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
I am running 62cc Livernois Stage 3 243 heads with 0.036" Cometic gaskets on a stock LS2 short block for 11.7 to 1 static CR. New GM head bolts. No leaks, and lots of fun with a tiny 224*/228* 0.595" cam.
Old Jan 12, 2010 | 06:16 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
We chased a loss of coolant for 3 months back and forth. It was a very small amount, but over time it all adds up. The motor was built by CRD and block and heads had a better finish then stock. It ended up being the Cometic gaskets. I talked to Cometic about it and they said they have never heard of an issue. The motor went back together with factory gaskets. I will say this, it didn't leak until the motor had about 7500 miles on it. I was on the fence about trying them again, and to be honest I will probably put them on my car and try but not on a customers.
Old Jan 12, 2010 | 07:56 PM
RoadRebel's Avatar
RoadRebel
They have revised their gaskets numerous times (Gee wonder why) in the past 5 years and IMHO they still SUCK! I as well quit using them due to numerous issues with coolant. I had a customer supply his own parts (may 09) and insisted to use them with his "Package". Well 5 months later I got the phone call needing a coolant issue resolved. Its a Dam shame when something that 3x+ the cost doesnt perform as well as the OEM.
Phil
Old Jan 12, 2010 | 08:39 PM
LSCHLEM's Avatar
LSCHLEM
Phil
I'm scratching my head on this one. I know I must get it right the first time. This next 35 or 40 RWHP is going to be expensive and I now wonder how much of a bump the COMEDIC would be over the OEM ?
Old Jan 12, 2010 | 08:47 PM
cencalc6's Avatar
cencalc6
I running .040 Comedic's on my LS7 with No Problems
Old Jan 12, 2010 | 09:56 PM
LSCHLEM's Avatar
LSCHLEM
Guy, I know the 232 Cam is not optimal for peak numbers but it is close
to being optimal for a cam with zero issues with tons of torque for a DD.
I will only know if I can reach 500 buy putting the trick flows on and the tractionmonster TIRE & WHEEL setup , make a trip to the DYNO then straight to the track for that 129 mph run. Thanks for your input as I work out the final details on the Heads & Gasket combo.
To Will cometic head gaskets leak coolant ??
Old Jan 12, 2010 | 10:33 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
23,000 miles and 2.5 daily driving years and 250 drag strip runs on my cometics, no problems. My shop uses them all the time and I've never heard of any problems.
I want Trick Flows myself, but the price is close to a Grand Sport Wide body kit and I can't decide. Good thing I don't have the money for either!
Plus I'm afraid my beloved stock clutch might meet its match if I upgraded my heads.
Old Jan 12, 2010 | 11:25 PM
SpinMonster
Tq is an issue of proper DCR. My bigger cam (specs undisclosed yet) will have less overlap than this 232 cam and will drive better. It will also beat it everywhere under the curve. It will break 500rwhp and run a 132mph.
Old Jan 13, 2010 | 09:13 AM
dfinke23's Avatar
dfinke23
I'm running Cometic .040's on my 467 LS7 with no issues. ARP head studs, copper coat and re-torque after heat cycle.
