Rpms
sorry if this seems like a dumb question.
End result: LS3 gets lots of low end grunt and does not need to rev that high. Saves money also, and gas.
I had an E46 M3 that redlined at 8k. The M3 had a 3.2 litre 333 hp/ 262ft.lbs of torque vs the corvettes 6.2 LS3 436 hp and 428 ft.lbs of torque.
The M3's engine was almost half the size of the LS3 and had 166 ft.lbs. of less torque, but it loved to rev to 8k!
Why doesn't the LS3 rev to 8k?
Expense - the materials costs would drive up the price of a base vette.
Reliability - increase stress on materials can reduce engine life.
Marketing - GM has the LS7 which redlines at 7k., the expense of an
8k reving LS3 would be closing the gap on the Z06 pricing.
I hope this helps
I had an E46 M3 that redlines at 8k. The M3 had a 3.2 litre 333 hp/ 262ft.lbs of torque vs the corvettes 6.2 LS3 436 hp and 428 ft.lbs of torque.
Marketing - GM has the LS7 which red lines at 7k., the expense of an
I hope this helps
An simple valve spring change and some tuning might even allow it to rev to 7000 rpm quite easily too I'd bet though I don't know if there would be any power gains attained by doing that on the stock cam.
