key fob dead?
Old Jan 19, 2010 | 10:49 AM
luckycharmer03's Avatar
luckycharmer03
Default key fob dead?
Hey guys! I went to open my door today and it wouldn't open...should I assume it is definitely the Key Fob battery and get a new one? Thx
Old Jan 19, 2010 | 02:09 PM
RyanC7's Avatar
RyanC7
or your battery on the car is dead......
Old Jan 19, 2010 | 02:12 PM
Crow Hunter's Avatar
Crow Hunter
It could be the car's battery is dead. Did the little red LED door indicator light come on? Key fob batteries are good for about three years depending on usage. They are easily and inexpensively replaced. Plus, the fob doesn't have to be "re-programmed" to the vehicle. Try the other function tabs on the fob. If the hatch opens as it should then it's not the fob battery. Push the lock tab. Do the car lights flash?
If all of the above tests are OK, it might be the touchpad mechanism used to unlock and open the doors. If so, they can also easily be replaced.
Old Jan 19, 2010 | 02:33 PM
Kent1999's Avatar
Kent1999
1st: Make sure your main car battery isn't dead.
2nd: Make sure it isn't radio interference from a nearby cell phone or other source. (it is common for the fob not to be recognized if its in the same hand or pocket as your cell phone)
3rd: Replace key fob battery -- its like $2 at WalMart, and about 45 seconds worth of work to replace. I would definitely do that *before* expending any additional funds or effort chasing down other less likely possibilities.
Cheers,
Kent
Old Jan 19, 2010 | 02:47 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
just had same prob.if the red led is blinking when you try to open the door...then it is ur fob batt....replaced mine and it works great now....$5 fix
Old Jan 19, 2010 | 08:21 PM
luckycharmer03
yes the light would blink red when trying to open the door. funny thing is later on in the day i tried again and it opened no problem. guess its on the verge of dying? everything else with car works..so guess ill make that trip to walmart. thanks guys!
Old Jan 31, 2010 | 01:17 PM
mikerms's Avatar
mikerms
2nd Gear
don't be so sure that it is the battery in the fob , i had the same thing happen to me and then the car was fine for few days and stopped working again after opening the car via the trunk i got the the engine compartment and found that i had a loose battery connection
Old Jan 31, 2010 | 01:53 PM
HOXXOH's Avatar
HOXXOH
When replacing the fob battery, avoid Rayovac. Those have a gridded negative face and don't make consistant contact with the spring connector in the fob. Use only batteries with a smooth negative surface.
http://forums.corvetteforum.com/c6-c...post1572939623
Old Jan 31, 2010 | 03:03 PM
saplumr's Avatar
saplumr
You have 2 fobs and they won't go dead at the same time. Try the other one.
Old Feb 1, 2010 | 04:03 AM
LS1LT1's Avatar
LS1LT1
Extreme cold temps can effect a fob's operation as well, at least it did for mine a few times. I had left it in my other car one day when it was roughly 25* outside and when I went to take the Vette for a spin that night the fob wouldn't open the doors for me (neither automatically nor by hitting the buttons) and it took me a minute or two to figure out that it was the cold that caused it. After warming it up a little bit between my hands it worked fine.
Now do keep in mind that I also still have the original fob battery (almost 4 full years old at the time) in it as well so I might drop a new one in there and see if leaving it in the cold will still cause the same issue.
Old Feb 1, 2010 | 03:46 PM
saplumr's Avatar
saplumr
Might as well by 2 batteries. The one I use most lasted 5 years but I changed both at the same time to be safe.
Old Feb 1, 2010 | 04:52 PM
LS1LT1's Avatar
LS1LT1
Good idea, I only use one fob/remote and have never even used the 2nd once since I'd bought the car but that one's battery is probably still pretty worn down as well.
Old Feb 3, 2010 | 02:59 PM
ALSVETTE05's Avatar
ALSVETTE05
3rd Gear
I have same problem,had the batteries checked at radio schack,they said batteries are good on both fobs,still cant get in what do i do next?
Old Feb 3, 2010 | 03:38 PM
Unreal's Avatar
Unreal
I'm glad I read this. I got my z06 last week and the second fob didn't work. Replaced the battery with a rayovac and still didn't work. Dealer tried to program and said it looks like battery was dead but I assured them it was a brand new battery. Looks like I'll try swapping batteries and see if that fixes it.
Old Feb 3, 2010 | 05:46 PM
Unreal's Avatar
Unreal
Swapped the rayovac for a energizer and it worked right away.
To key fob dead?
